Supply/return lines on frame 1995 7.3 crew cab - Ford Truck Enthusiasts Forums
Old 08-25-2014, 10:40 PM
HOOTs95PSD HOOTs95PSD is offline
HOOTs95PSD is starting off with a positive reputation.
Truck is a 1995 F350 XLT 7.3 E4OD crew cab .
What size are the fuel lines on the frame?
Most of mine are gone completely. I have 3/8 SS tubing here to make most of the runs. I also have plenty of rubber fuel line for connectors. Is the tubing OK or too big , small?
I see repair tubes for gas but not for diesel. I'm thinking pulling a set from another truck will just be asking for trouble and leaks.
I have a double flaring tool and a Bubble flaring tool. Or should I use a compression fitting to attach a brass or SS ferrule to the tube then cut the nut off and have the ferrule as a rubber hose clamping area.
I have the tubing and brass and SS fittings here already.
Anyone have any thoughts or answers?
Thanks
Old 08-26-2014, 07:48 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
3/8 should be fine. I think the stock lines are somewhere in the 3/8 or 5/16 range. All the connections are very low pressure (suction on the supply and more or less no pressure on the return) since the pump is on the motor, so you don't have to worry a ton about the connections. Make sure they're tight, so you don't suck air past them on the supply line since it is suction, but there is little or no concern of blowing them apart so I wouldn't be overly worried about that. Just make sure you have a snug connection and you should be fine.
Old 08-26-2014, 08:10 AM
David7.3's Avatar
David7.3 David7.3 is offline
Where is the beer?
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
DIY is correct 3/8 is the supply line and 5/16 is the return line from factory, Inline tube makes a complete set from tank to engine, available in stainless steel. coated steel and aluminum. Its saves alot of time, you pay more but no rubber connections, everything is factory and the fit is awsome.
Old 08-26-2014, 04:03 PM
I'll look into Inline Tube.. Never thought of them . I run them on my Jeep. SS brake lines.
I'm pretty good with a set of benders but if I can get them preformed and correct for a decent price.... That's for me .
I want to add the larger tank in the rear also so maybe this will just be one big project weekend, when it happens.
Thanks
Compression fittings Aluminum only??? underthebridgejim 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 02-17-2016 11:34 AM
Fuel tank return line 49fordv8f4 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 12-21-2015 07:19 PM
Another awesome 'custom' veggie conversion - 7.3 PSD SkySkiJason Bio-diesel, Propane & Alternative Diesel Engine Fuels 5 09-18-2015 10:35 AM
96 F150 4.9L A.I.R. mainfold tube and ferrules jb50F1 1987 - 1996 F150 & Larger F-Series Trucks 11 09-07-2014 09:03 PM
Return Fuel line Removal f250macdaddy 1999 to 2016 Super Duty 2 06-06-2014 02:15 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
