Adjustable Vacuum Advance - 300 Six? - Page 2 - Ford Truck Enthusiasts Forums
Old 08-26-2014, 03:25 PM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Quote:
Originally Posted by ctubutis View Post
Using slang terms keeps Google from identifying threads (text) where good information may be found.
Unless they are using slang terms to search...
I thought that was what thread tags were for?
Not that I usually add any.
Old 08-26-2014, 03:49 PM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
Quote:
Originally Posted by Gary Lewis View Post
I don't know the answer to that. Just that Crane doesn't say it will fit. They only list the V8's. If no other option presents itself I'll order a Crane from Amazon and if it doesn't fit either return it or use it on Rusty.
I went to Crane Cams web site and fired off an email to the Customer Service as well as the Technical Department, requesting assistance. As soon as I hear back, I will report.
Old 08-26-2014, 05:18 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is offline
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
David - Good idea! Perhaps they will answer the question. And, I just realized that I have one of the Crane adjustable units on the dizzy for Dad's truck. So if we don't have an answer before you are here we can see if that one fits and I can replace it later.
Old 08-26-2014, 07:30 PM
JayzDaddy's Avatar
JayzDaddy JayzDaddy is offline
JayzDaddy is gaining momentum as a positive member of FTE.JayzDaddy is gaining momentum as a positive member of FTE.
When i asked can or dizzy i was sure Gary knew what i was asking. Never thought about inexperienced people questioning the terminology.
My apologies
Old 08-26-2014, 07:40 PM
Gary Lewis's Avatar
Gary did know and yet he didn't think about searches. Will try to keep that in mind.
Old 08-26-2014, 08:40 PM
pedant
So, there's still no tags for this thread????
Old 08-26-2014, 09:01 PM
pedant
I was just looking at the pictures in Dylan's thread.
It seems the 300 distributor rotates the opposite direction.
At least, the advance unit has the arm reaching out the opposite side.
Not sure if you can just flip the advance over, and I have NO idea why he has a points distributor in his hand.
Old 08-26-2014, 10:41 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Quote:
Feel free!
But I have to tell you, I usually end up deleting many/most of them (when people bother to add them) and that's because people enter them wrong...
One can make a tag consisting of multiple words, PLEASE DO THAT and do NOT separate each word with a comma as that creates separate tags that are pretty much worthless by themselves.
Ex:
1986, Ford, red, truck
I will delete all that wholesale as each tag, by itself, is pretty useless
i put some tags in some of the subforum threads that I hope might be useful and represent what the thread describes and not something generic and useless.
Old 08-26-2014, 11:36 PM
Gary Lewis's Avatar
First, why would this thread need tags? Or, maybe better, why would someone want to find it in a search? Until the revelation that the 300's dizzy rotates the opposite way, which I should have tumbled to because of the timing gears instead of sprockets, there's been no information. Just lots of questions.
However, with that revelation we have the makings of information. I'll pull out a vacuum advance for an eight tomorrow as well as a dizzy and see if it looks like turning the advance upside down would work. Thanks, Jim!
Old 08-27-2014, 06:02 AM
pedant
I should have been the one thinking, since I was the one asking "why not?"
At least I'm observant enough to notice something when it is right up in my face.
Old 08-27-2014, 08:03 AM
Gary Lewis's Avatar
I saw the same pic and didn't catch it. Glad you did, for sure. Otherwise I would have had a rude awakening when turning David's dizzy to change the timing. Not sure how long it would have taken to awaken "the little gray cells".
Old 08-27-2014, 08:12 AM
pedant
Maybe the screws would have to go in through the bottom?
Not sure if the distributor or the advance unit is what is threaded.
  #28
Old 08-27-2014, 08:29 AM
Gary Lewis's Avatar
I think it is the advance, but will check in a bit. Meanwhile back at the ranch, David found the original dizzy for his engine and it had the tag. So I should be able to find it in the caliber ration codes and find the number of the vacuum advance. Then, if that advance is used on an 8 we will know they interchange. However, since I think there is at least the issue with the screws I doubt it. But that doesn't mean it can't be done.
  #29
Old 08-27-2014, 09:34 AM
Okay, I heard from Crane and their response was that they do not know if what they offer will work, since it is specified for V8s.
I brought the distributer I used before the one I purchased from Performance Distributors to work and made use of a set of long shank allen wrenches and found that the vacuum canister IS adjustable [from a 1982 F150]. The magic number is: 1/8".
In a little while, I will go to my truck and confirm that it, too, is adjustable. Both canisters are Motorcraft, so I believe it will be.
Thanks, guys!
  #30
Old 08-27-2014, 09:51 AM
Gary Lewis's Avatar
Yippee! Cool! So forget the PM I just sent you re calibration code. But, for the rest I found his 82 dizzy's # (E1TE 1217-ZA) in a calibration code for an 81, and a similar one (E3TE 1217-ZA) for an 83, but can't find that code for an 82 like his.
300 six vacuum? brian.b 1973 - 1979 F-100 & Larger F-Series Trucks 1 09-23-2016 09:06 PM
Distributor conversion on a 223 six. Daddyo's garage 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 05-31-2014 02:22 PM
Low Vacuum/Carb Problem Carter YF jbwolfe Ford Inline Six, 200, 250, 4.9L / 300 13 12-01-2012 11:57 PM
I6 vacuum problems PLease Help. sausrigging 1968-2013 Full Size Vans 1 05-28-2006 01:20 PM
300-6 Book? micah Ford Inline Six, 200, 250, 4.9L / 300 5 05-17-2000 10:00 PM
Tags
i-6 distributor rotation
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
