Name of this water outlet part? - Ford Truck Enthusiasts Forums
Old 08-25-2014, 07:42 PM
Junior Junior's Avatar
Junior Junior Junior Junior is offline
Junior Junior is starting off with a positive reputation.
Hello again, fellas. When replacing the thermostat on my '82 F100 straight six, I broke the right side flange on my water outlet/thermostat housing because I'm a gorilla, so I know I need a new one.
However, the part attached that connects the heater core and some vacuum lines is absolutely seized on and will not come off without being destroyed as well. What exactly is this piece called, so I know what to ask for when getting a new one? Not one of the three books I have has anything about this.
Same goes for this plastic vacuum piece, which I should probably replace as well:
While I'm at it, which aftermarket water outlet fits and works the best? One review on Advance said the one they offer doesn't have enough space for the bolt heads. That sounds kinda crazy and terrible and I've had enough of both for now.
Any and all help is much appreciate as always.
Old 08-26-2014, 01:42 AM
oneowner83 oneowner83 is offline
oneowner83 is gaining momentum as a positive member of FTE.oneowner83 is gaining momentum as a positive member of FTE.
Not sure of the name but I had that same problem with Auto Zone...the holes for the bolts holding the thermostat housing were aligned wrong....you couldn't get a socket on the bolt head. Wherever you buy one take the bolt and socket with you to test.
Any and all help is much appreciate as always.[/quote]
Old 08-26-2014, 05:12 AM
bill06447 bill06447 is offline
bill06447 is gaining momentum as a positive member of FTE.
That's the vacuum delay valve. Works with the EGR though this one appears combined with another delay valve (the vacuum diagram on the radiator support will tell for sure) ~Bill
Other than Fords what are you addicted to? Yahiko 6.0L Power Stroke Diesel 50 12-29-2016 04:46 PM
Somethin's fishy(front spring) CharlyG Excursion - King of SUVs 24 09-20-2016 11:46 AM
1979 Ford F150 Custom restore 79Ford-4x4 1973 - 1979 F-100 & Larger F-Series Trucks 16 04-29-2016 06:43 PM
86 F250 Part out- 6.9 IDI, 4x4 diesel cowboybootlegger Ford Truck Parts for Sale 0 02-03-2015 09:54 PM
Water Pump / AC Comp bracket questions - 1992 460 SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 9 08-12-2014 06:40 AM
Tags
1982, cooling, f100, gooched, thermostat housing, water outlet
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
