I installed a new glow plug controller today. I wasn't sure I really needed one or if it was the glow plugs, until I removed it. Yep I think its bad, here is a pic of it.
you should ohm out your glow plugs just to be on the safe side, it's easy with a OHM meter, unplug glowplug touch one lead to ground the other to the glowplug terminal and you should get about 4 ohms, cold. That way you know your ready for winter and you wont melt anything else.
