223 push rod cover - Ford Truck Enthusiasts Forums
223 push rod cover
Old 08-25-2014, 05:30 PM
69 f-100 aman 69 f-100 aman is offline
69 f-100 aman is new and has a neutral reputation at this point.
223 push rod cover
does anyone know what the torque is on the push rod cover bolts, thanks
Old 08-25-2014, 05:58 PM
teardropty's Avatar
teardropty teardropty is offline
teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.
It's been awhile but not very tight, MAYBE 15-20. Someone with more definitive answers will be along soon. Sadly many of the push rod covers on the 223s leak regardless of having a new gasket.
Old 08-25-2014, 06:15 PM
Yes, Im finding that out, was just seeping and changed gasket and now its a leaker! Didn't tighten it very tight either
Old 08-25-2014, 06:33 PM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is offline
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
1956 Ford 223 Inline Six Engine Specs
This should provide you with what you need.
Old 08-25-2014, 07:38 PM
Thanks, but it has everything except push rod cover bolts torq.
Old 08-25-2014, 07:52 PM
I looked up for a 300 six and it said 2 ft.lbs. so I'll go with that. Thanks everyone for your help
Old 08-25-2014, 08:11 PM
clintonvillian clintonvillian is offline
clintonvillian has a very good reputation on FTE.clintonvillian has a very good reputation on FTE.clintonvillian has a very good reputation on FTE.
My shop manual list 8-10 ftlbs on the oil pan but nothing on the sidecover.
I would add a thin coat of RTV to w\each side of the gasket.
Old 08-25-2014, 08:14 PM
I will also do that! thanks
Old 08-25-2014, 10:35 PM
teardropty's Avatar
Honestly, I did away with my gasket. The newer Felpro gaskets just doesn't seem to fit the shape of the casting and cover. I used a gasket maker sealant and did away with the felpro. Also, watch the grommets that the bolts go through, the newer ones are a little different shape than the originals, again a little sealant helps. Good luck.
Old 08-26-2014, 05:42 AM
I will give it a try Thanks
Old 08-28-2014, 06:35 PM
after 4 tries I think I got it to stop leaking, ran it for about 30 mins. and still dry and no leaks
Old 08-28-2014, 09:51 PM
teardropty's Avatar
Congrats! I love the 223s but the oil leaks they have can be frustrating.
Old 08-29-2014, 08:58 PM
what did you finally decide on to fix the issue?
Old 08-29-2014, 11:40 PM
did away with gasket and used a good RTV sealant and let is set for a hour or so and then put it on,also put a little bit on each rubber bolt hole and just can of snugged it down and let it set till the next day.... So far its not leaking Just make sure its good and clean and eng block is clean
Old 08-30-2014, 03:00 PM
teardropty's Avatar
Quote:
yep, you did it right... gaskets are a pain on the cover.
no oil running under rocker cover waco1313 1994.5 - 1997 7.3L Power Stroke Diesel 2 12-07-2015 11:25 PM
Clutch push rod gtcrackers 1957 - 1960 F100 & Larger F-Series Trucks 12 10-01-2015 09:35 PM
Performance TV and Push rods X-Hibition 6.0L Power Stroke Diesel 9 11-04-2014 08:51 PM
Push Rod Cover emgee Ford Inline Six, 200, 250, 4.9L / 300 4 09-07-2010 09:32 PM
Push rod replacement BstangBill 6.0L Power Stroke Diesel 7 02-15-2010 12:21 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
