223 push rod cover
Old 08-25-2014, 04:30 PM
69 f-100 aman's Avatar
69 f-100 aman
69 f-100 aman is offline
223 push rod cover
does anyone know what the torque is on the push rod cover bolts, thanks
Old 08-25-2014, 04:58 PM
teardropty's Avatar
teardropty
teardropty is offline
It's been awhile but not very tight, MAYBE 15-20. Someone with more definitive answers will be along soon. Sadly many of the push rod covers on the 223s leak regardless of having a new gasket.
Old 08-25-2014, 05:15 PM
69 f-100 aman
Yes, Im finding that out, was just seeping and changed gasket and now its a leaker! Didn't tighten it very tight either
Old 08-25-2014, 05:33 PM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is online now
1956 Ford 223 Inline Six Engine Specs
This should provide you with what you need.
Old 08-25-2014, 06:38 PM
69 f-100 aman
Thanks, but it has everything except push rod cover bolts torq.
Old 08-25-2014, 06:52 PM
69 f-100 aman
I looked up for a 300 six and it said 2 ft.lbs. so I'll go with that. Thanks everyone for your help
Old 08-25-2014, 07:11 PM
clintonvillian's Avatar
clintonvillian
clintonvillian is offline
My shop manual list 8-10 ftlbs on the oil pan but nothing on the sidecover.
I would add a thin coat of RTV to w\each side of the gasket.
Old 08-25-2014, 07:14 PM
69 f-100 aman
I will also do that! thanks
Old 08-25-2014, 09:35 PM
teardropty's Avatar
teardropty
Honestly, I did away with my gasket. The newer Felpro gaskets just doesn't seem to fit the shape of the casting and cover. I used a gasket maker sealant and did away with the felpro. Also, watch the grommets that the bolts go through, the newer ones are a little different shape than the originals, again a little sealant helps. Good luck.
Old 08-26-2014, 04:42 AM
69 f-100 aman
I will give it a try Thanks
Old 08-28-2014, 05:35 PM
69 f-100 aman
after 4 tries I think I got it to stop leaking, ran it for about 30 mins. and still dry and no leaks
Old 08-28-2014, 08:51 PM
teardropty's Avatar
teardropty
Congrats! I love the 223s but the oil leaks they have can be frustrating.
Old 08-29-2014, 07:58 PM
clintonvillian
what did you finally decide on to fix the issue?
Old 08-29-2014, 10:40 PM
69 f-100 aman
did away with gasket and used a good RTV sealant and let is set for a hour or so and then put it on,also put a little bit on each rubber bolt hole and just can of snugged it down and let it set till the next day.... So far its not leaking Just make sure its good and clean and eng block is clean
Old 08-30-2014, 02:00 PM
teardropty's Avatar
teardropty
yep, you did it right... gaskets are a pain on the cover.
Quick Reply: 223 push rod cover
