What should be here? - Ford Truck Enthusiasts Forums
Old 08-25-2014, 02:46 PM
Fifty4F100's Avatar
Fifty4F100 Fifty4F100 is offline
Fifty4F100 is gaining momentum as a positive member of FTE.Fifty4F100 is gaining momentum as a positive member of FTE.
I am having some small problems with the 6.8 in my F53 MH chassis. It runs like a top, but has a little idle lope. To those who looked at my previous thread, its better. But while checking for vacuum leaks I found this:
I thought it would be something that moved. But what's there and bolted down is actually the rear of the intake manifold. What's supposed to be here?
Old 08-26-2014, 07:28 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Subscribing... no clue.
Old 08-26-2014, 09:28 AM
Bumble Guy Bumble Guy is offline
Bumble Guy is starting off with a positive reputation.
I have a 1999 class a motorhome same v 10 . Mine is same as second picture
Old 08-26-2014, 03:43 PM
northwindone's Avatar
northwindone northwindone is offline
northwindone has a very good reputation on FTE.northwindone has a very good reputation on FTE.northwindone has a very good reputation on FTE.northwindone has a very good reputation on FTE.
Looks like the one in this thread...
http://www.ford-trucks.com/forums/13...l#post14152934
I learned a little bit later on another thread that it was normal for some V10s as would be suggested by the response from Bumble Guy. I'm still curious why they would do it like this, but that seemed to be the answer.
Old 08-26-2014, 04:31 PM
Quote:
I know it doesn't look right with the metal hose and the gasket not lined up but it is the same on my v 10 so I wouldn't worry
Old 08-27-2014, 04:33 AM
Im50fast's Avatar
Im50fast Im50fast is online now
Just Wannabe Acknowledged
Im50fast has a good reputation on FTE.Im50fast has a good reputation on FTE.Im50fast has a good reputation on FTE.
It's gotta be for EGR or vacuum something.
Where does the hose go?
And where does the other side go?
Old 08-28-2014, 08:28 PM
speakerfritz's Avatar
speakerfritz speakerfritz is offline
speakerfritz is gaining momentum as a positive member of FTE.speakerfritz is gaining momentum as a positive member of FTE.
this reminds me of my aircraft inspection days. mechanic's would do a great job on the bolts that they thought I could see and a crappy job on the bolts they thought I could not see.....but I used an inspection mirror and can see all the bolts.
so my take, this is a short cut on the assembly line and mechanics are putting in one bolt thinking the inspector cant see the other. later during service life of the vehicle...the two parts shift out of position and you have them hanging on out of alignment by one bolt.
the difficulty in trying to determine if it is a case vent is that multi cylinder engines equalize their case pressure as pistons move in and out resulting in no real sense of case vacume or pressure if you put your finger in the whole.
Old 08-31-2014, 08:08 AM
Im50fast's Avatar
weird... mine has it too. It is a passage to nowhere; i shined a flashlight up from the bottom and the light comes through the top.
Old 08-31-2014, 11:08 AM
khxor's Avatar
khxor khxor is offline
khxor is starting off with a positive reputation.
That's a hole to nowhere. The Heads are interchangeable left to right, when installed on the left side that's at the front, coolant passage to the intake manifold for the t-stat. On the right it's there at the back, it's completely normal.
'55 panel build sstephanuik 1948 - 1956 F1, F100 & Larger F-Series Trucks 146 02-16-2017 01:53 AM
1982 150 XLT Lariat 4X4 Value Youthdude 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 27 12-23-2016 08:10 PM
Caution Ford GT Porn chruby99 General Automotive Discussion 8 12-20-2016 08:27 PM
Before and after pics-wheels and Leveling kit PwerStroke99 2017 Super Duty 17 11-01-2016 02:24 PM
Finally! drivesprocket 2017 Super Duty 17 09-09-2016 09:15 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
