Coil replacement options
Old 08-25-2014, 01:06 PM
whateg01's Avatar
whateg01
whateg01 is offline
Just replaced the plugs on my '00 F150, 5.4L, and was surprised at how easy it was. Cleaning the holes out beforehand was a different story. I spent a lot of time with an air hose and blow gun in hand. Anyway, it's a new-to-me truck, so still getting all the bugs worked out. Before I replaced the plugs, I couldn't get any indication of a miss anywhere other than the seat of my pants. After replacing the plugs, I get a P0302, IIRC. Miss on #2. So, I will swap #1 and #2 coils or something like that to confirm that it's a coil problem. Assuming the coil is bad, it looks like I have a few options.
Parts store house brand for $50+. Rockauto off-brand for $20 or less or Motorcraft for $40 each. Accel on Amazon for either $25 each or $170 for a set of 8. There are some others online for as little as $7 or $8, but I'm not taking that chance.
So, the truck has 219k on it. Not sure the plugs have ever been changed before. Best one was at 0.068", worst was 0.098", but most were 0.088". I've heard that that kind of stress on the coils is bad for them, so are they all due for replacement? Or, do I spend a bit more on a single Motorcraft?
What would you do?
Old 08-26-2014, 10:07 AM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
I would go Motorcraft, especially if you can get them for $40
Old 08-26-2014, 04:23 PM
Driver Jim's Avatar
Driver Jim
Driver Jim is offline
Agreed. Motorcraft is the OEM part anyway. As the truck has turned 200k, I'd just do all of the coils at once for my own peace of mind.
When you do them, remember to put some dielectric grease in the connectors as they are exposed to the elements under-hood. Also beware of frail connectors as they are more than likely brittle with age.
Old 08-28-2014, 07:40 AM
JWA's Avatar
JWA
JWA is offline
Received 1,393 Likes on 1,102 Posts
I'm one who's "been there, done that........" with aftermarket COP's, Granatelli brand to be exact. Along with my own miserable experience and the numerous threads about so-called cheaper COP's time and time again it seems we all come back to Motorcraft. While Standard Motor Products are thought or said to be the very same thing it seems only the known better brands are best for one time and done installation.
Naturally it all comes down to money and even IF the name only is an excuse to charge more its very very rare seeing the Motorcraft brand of COP's or plugs not living up to expectations. Autolite plugs are the same as Motorcraft so in that single incidence a substitute is available.
Old 08-31-2014, 11:58 PM
whateg01's Avatar
whateg01
whateg01 is offline
Well, thanks for the advice. I ordered and installed one new Motorcraft coil. Well, it says Ford and Motorcraft on the bag. It also says that Motorcraft has different manufacturers so there may not be any marking on the coil. Installed, though, and the #2 misfire is gone. Then I noticed that occasionally, I still feel a miss. Not sure I can pin down what conditions it happens under, but it shows up on the Mode 6 data as #1, so I guess I'll order another. I have considered replacing them all at once, but I really think I need to spread them out for the time being. I just put tires on the truck and I still need to replace the windshield, and until the old truck is gone, I'm a little in the red.
Dave
Old 09-28-2014, 09:43 AM
8092shrtbx's Avatar
8092shrtbx
8092shrtbx is offline
just my oppinion but you dont have to buy motorcraft. just buy a quality part. im running the higher amp summit blue COP's and my buddy is running the MSD COP;s. neither one of us has had any problems working fine in both trucks. just throwing out options for you
Old 09-28-2014, 01:16 PM
trozei's Avatar
trozei
trozei is offline
I went to the dealer yesterday to buy new coils and plugs for all 8. They wanted $26 per plug and $145 per coil. I laughed, went home, jumped on Rockauto, and ordered OEM plugs for $10 and OEM coils for $50.
Old 09-30-2014, 12:20 AM
Modularation's Avatar
Modularation
Modularation is offline
Dave
There is a sticker under the hood that says Motorcraft ignition parts for best performance and seasoned mechanics know this is good advice. The risk you run of not changing all eight stressed COP's is one that fails CAN take out the coil driver in the ECU requiring computer replacement at a much greater cost.
xtal_01
1999 to 2016 Super Duty
12-10-2015 05:58 AM
xtal_01
12-09-2015 02:23 PM
Tommy B405
08-05-2015 07:38 AM
F0rdE$cape
Escape & Escape Hybrid
04-15-2015 10:38 PM
sniknah
1997 - 2003 F150
05-18-2011 06:23 PM
Quick Reply: Coil replacement options
