Anyone in Central Texas up to help with Tank mods?
Hey, the procedure looks pretty straight forward but I'd prefer having someone around who's done it. I was planning on pulling the bed instead of dropping the tank. I've got a decent tool arsenal and cold beer. I start cutting out at about half a tank. Sucked this past weekend pulling my camper! Anyways, If you're around Killeen and up to give me a hand, pm me or post here.
Thanks,
Brian
Thanks,
Brian
The tank is plastic so if you can siphon all the fuel out the tank can easily be held up by one person vs four for the bed. For tools you just need the correct socket for the straps, fuel line removal tool and a PVC pipe cutter. If your removing the mixing chamber then add in a metal pipe cutter and a few wrenches to turn the compression fitting.
tracyclifton
6.7L Power Stroke Diesel
12-31-2015 10:43 AM
oldfordisbetter
31
03-11-2011 07:45 PM
