hard/no start, rough idle, white smoke
Need to check the factory fuel line connections for leaking air.
Although not sure any of these will account for white exhaust.
checked the filters but completely spaced the hutch and harpoon mods. talked to a ford tech who said the greenish stuff in my fuel is algae. not happy about hearing that at all. he recommended an additive that I can get through the quick lane at the dealership for around $40. this morning it smoked white for a while right after I started it but it was running so I let it warm up. by the time I got ready to leave for work, it had cleared up and ran fine.
I didn't read every post here, but I was just having the same type of symptoms. An easy thing to do to figure out, pull the housing off the pressure relief valve on the drivers side top of the fuel bowl. On my truck, the valve was broken and needs to be replaced. I located the spring for the valve inside the tubing before the first bend, obviously not where it should have been....
The fuel bowl needs to hold pressure. I could be just something stuck in there allowing pressure to drop between starts, causing the hard or no start condition. Mine was doing the same, white smoke and all. Replacement parts are available.
Good luck.....I know we can sometimes beat our heads against the wall and over look the simple things.....
i'm gonna check that valve here in a minute. that would be awesome if that was all it was. i've heard suggestions to check everything from clogged fuel filter to a melted piston. knowing that you had the same symptoms is encouraging. do you remember where you got the replacement parts? and do you have a picture or anything showing where that is? i think i know what you're talking about but i'm not positive.
Did you get the algae killer in there? Algae in the tank can cause intermittent blockage, and you'll starve for fuel which will be crappy running no power and often plenty of white smoke. Run the biocide for a tank then drop it and do the hutch and harpoon mod. If those screens are cruddy you found the problem.
Can you see diesel in the degas bottle? Just a whiff could be from the other work done on the fuel bowl.
Injector cups are often done by others on the forum. Sometimes a couple few times. It isn't rocket science but it does need to be done carefully.
Vankaye
1999 to 2016 Super Duty
13
08-22-2018 01:28 PM
supersmoke
11-21-2013 04:55 PM
gbeach
18
07-07-2008 07:09 AM
