Excessive white smoke, backfire.
Old 08-25-2014, 11:54 AM
bubba_3711's Avatar
bubba_3711
bubba_3711 is offline
Pickup starts and runs fin untill about 1,800 rpms then it barrels out white smoke and back fires.
Old 08-25-2014, 01:33 PM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
That doesn't sound too good! Check your fuel filter and see if it's all black and oily looking.
Old 08-25-2014, 03:17 PM
bubba_3711's Avatar
bubba_3711
Nope fuel filter looks good, full of fuel. Changed the CPS and same symptoms.
Old 08-25-2014, 04:03 PM
bubba_3711's Avatar
bubba_3711
Also Injectors and turbo has less then 10,000 miles on them. New fuel filter.
Old 08-25-2014, 08:25 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
Broken valve spring or burned valve, maybe?
Old 08-25-2014, 09:23 PM
fordpride's Avatar
fordpride
fordpride is offline
When you say "backfire" is it coming from the exhaust or air intake filter ?
Old 08-25-2014, 10:56 PM
bubba_3711's Avatar
bubba_3711
Possibly valve spring or burnt valve. I was racing when it started.
It's coming from the exhaust. Sounds perfectly normal until about 1,800 rpms. When it starts missing at 1,800 and I let off the throttle it sounds normal then climbs to about 2,000 rpms before the rpms drop back down.
Old 08-26-2014, 06:03 AM
DIYMechanic
If you were racing when it happened I think I would open up the valve covers and look for a broken rocker or bent pushrod.
gbeach
01-23-2015 03:58 PM
SolidCitizen94
11-20-2013 09:14 AM
PJ-Hunter
16
06-12-2013 08:04 PM
countermouse68
03-01-2011 02:08 PM
TourqueRise
19
08-27-2009 11:10 PM
Quick Reply: Excessive white smoke, backfire.
