75 F700 probs - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
75 F700 probs
Old 08-25-2014, 11:29 AM
jimspop jimspop is offline
jimspop is starting off with a positive reputation.
75 F700 probs
I have a 75 F700 fire pumper with a 390. Just put in new points etc. Didn't want to pull a load or rev up. Loosened up a line from the carb to base of distributer, and it runs great. Tighten the line up- runs pooly again. I. no Ford guy, gut whats up????
Old 08-25-2014, 12:59 PM
351Cleveland C4's Avatar
351Cleveland C4 351Cleveland C4 is offline
351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.
What line are you talking about? The only thing that goes from carb to distributor is vac advance.
And you may be better off posting in the 73-79 forum. This is 67-72.
Old 08-25-2014, 01:15 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Welcome to FTE
I asked a moderator to move your thread to the LARGE TRUCK forum, this forum is for 1967/72. With an F700, you won't get much help in the 1973/79 forum which is mostly related to F100/350's.
Your truck does not have a 390 FE engine, as these were only installed in 1968/76 F100/350's and misc 1961/71 Passenger Cars.
More than likely it has a 391 4V FT engine.
Old 08-25-2014, 05:17 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
What happens when it won't rev or take a load? Does it miss, or just not rev?
That line might be the governor.
Old 08-25-2014, 06:02 PM
jimsop
It just won't rev. It will when the line is loosened up. Wold the gov be vacuum operated? I'm not a Ford or truck guy
Old 08-25-2014, 06:28 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Distributors and carbs in those trucks usually had a governor on them. If the gov were disturbed in some way, that might be an issue.
Usually we get the report that the engine will rev with no load, but no revs or power with a load. That is many times a fuel issue.
Since you were in the distributor, my guess is a governor issue.
The line from the carb to the distributor--loosening it up--what do you mean, did you disconnect it, unscrew it partially, what? Usually a line is either connected or disconnected.
Old 08-25-2014, 08:05 PM
jimspop
yes the line was disconnected and it ran well
Old 08-26-2014, 03:35 AM
big job's Avatar
big job big job is offline
big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.
Yes the gov. is vac operated and you dont have to be a Ford guy most
all work the same. What you say (and sounds like) the diaphram part on
the carb seems to be working, when the line is loose, sounds like the
pendulum in the distributor is stuck or the spring is broken? Although
a tough job while in the truck, its best to pull the dist out. There is two
lines there one from the gov to the diaphram Pass side (carb) and one
is the vent that goes (driver side) into the carb air horn for clean air.
To set these remove the clean air hose remove its barb on the dist. its
a square (barb) which is access to the gov. the bitch part is to turn
engine by fan or bump it till the pendulum comes around to the hole where
a allen set screw shows with allen wrench clockwise increase speed and
counter clockwise decreases speed against spring tention. Sounds to me
the pendulum is stuck out (centrifical gravity) which closes the clean air
line inturn gives vac. to the diaphram thus the engine wont speed up.
First test is take off the line at the diaphram while running put your finger
on the fitting there should be vac==race engine up then put finger back
on and the engine should idle no matter where the throttle is. If good the
problem is distrubutor. hope I my writing is understandable best I can say.
My bets are its a 391 with 2 or 4 bbl square bowl Holley notorious for
loading just about running- black smoking- when its rain & snow around 38 to 40 degrees they get carb icing. we run them for a minute shut down and
walk a way for a bit then restart they just need a little engine heat.
sam
Old 08-26-2014, 06:42 PM
jimspop
Would there be any problems with leaving the line disconnected?
Old 08-27-2014, 01:53 AM
big job's Avatar
No but I recomend some kind of air filter perhaps a small pill container with
some foam so it dont suck up something or them mud wasps get in there..
sam
1979 ford f700 1979fordf700 Large Truck 0 10-20-2016 04:41 PM
1996 F700 Brake Lines? berry1234 1987 - 1996 F150 & Larger F-Series Trucks 13 05-02-2016 03:35 PM
66 f700 brake parts tony fellman Large Truck 7 08-07-2015 12:50 AM
75 F700 oil Amon45-70 Large Truck 1 08-11-2014 09:27 AM
1996 F700 airbrakes frozen anthonyh75 Large Truck 3 01-30-2014 11:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
