What ifs - Ford Truck Enthusiasts Forums
What ifs
Old 08-25-2014, 10:40 AM
Shawn 82 Shawn 82 is offline
Shawn 82 is starting off with a positive reputation.
What ifs
Hi guys, looking at buying a ifs for my 51 f1 and wondering what you all are running and what kits to try avoiding? I m going to do airbags on all 4 corners and there are so many kits avaliable it's hard to make a decision? I was looking at going with a scotts custom front end then starting reading about complaints about the ifs and customer support? Any help would be appreciated I m ready to buy just hung up on which one
Old 08-25-2014, 11:27 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Stick with the quality name brands, ie; Heidts, TCI, Fatman, No Limit, etc. Air Ride Tech is a very good place to look for a full bag kit. Skimping at the beginning of your build on suspension won't do you any favors later, and will likely cost you way more than you thought you'd save.
Old 08-25-2014, 12:04 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Id stay far away from Helix or any of the other inexpensive no name Chinese clone junk. You get what you pay for.
Hope you have deep pockets, bags are super pricey.
Old 08-25-2014, 12:06 PM
yamagrant's Avatar
yamagrant yamagrant is offline
yamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputation
I don't have, but like the FATMAN stuff. Good luck.
Old 08-25-2014, 12:27 PM
Gicknordon's Avatar
Gicknordon Gicknordon is online now
Gicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to all
I used full tilt street rods for my front end. Its a good cheaper option and im pretty sure its made in house by the owner. If i was doing bags, i would get the full tilt crossmember and arms and the run shockwaves for the air bags. You can get them with the height sensors internal so you dont have to add any other sensors. I wwas planning on doing this until i saw the cost of the shockwaves plus the controlling unit needed to run them. I think it was close the 3 grand for it.
Old 08-26-2014, 08:12 AM
Thanks for the replies guys, I m going to put the majority of the money in the suspension and don't mind spending the money for quality parts, you definetly get what ya pay for and learned that lesson long time ago haha, I m seriously considering the tci front and back suspension cause of the extras they offer and certain times of year, I was going to go with the shock waves but have read somewhere where you can't drop as low with them as traditional bag and shock setup?
Old 08-26-2014, 02:58 PM
Rimrock F1's Avatar
Rimrock F1 Rimrock F1 is offline
Rimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud of
Quote:
I bought TCI front and rear. Have not installed yet but am very happy with the quality.
Old 08-27-2014, 09:44 AM
04Z06Vette 04Z06Vette is offline
04Z06Vette is starting off with a positive reputation.
I installed the stock mustang 2 control arms and fatman kit back in 1993 and did not had any problems with it. I had to play with spring rate to get the right ride height since I didn't use the typical SBC.
Old 08-27-2014, 05:34 PM
So at this point it's either tci or scotts hot rod? I like the scotts cause it's a one piece crossmember where as the tci is not unless you get the custom they offer. I m going to be running a 59 390 caddy motor in the truck so will have to fab up some motor mounts. I just got this truck in the past couple months from my grandfather and want to keep the caddy in it since it's been in there since 63
Old 08-27-2014, 07:39 PM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
I have the Fatman unit on my F1.
It came with the crossmember already installed on a frame that I acquired from 51Panelman.
Fatman was excellent with their customer service and helped me order all of the parts that I needed to complete the job.
They do have recommended springs etc. for big block engines. It might be worth a call to them before you decide.
Dan
TCI Custom IFS Hughmullersa 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 08-30-2015 03:21 AM
Which aftermarket IFS kit for a 63? Uni Moe 1961 - 1966 F-100 & Larger F-Series Trucks 6 10-11-2013 11:15 PM
IFS or Straight axle swap for 91' F250 WarPigF250 1987 - 1996 F150 & Larger F-Series Trucks 20 03-04-2012 08:04 AM
400M Rebuild kit? cgi2099 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 1 02-17-2012 11:23 AM
56 F100-getting started- frame SHARKS22 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 07-01-2011 03:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
