5.4L 3V Spark Plug Removal using Impact - Ford Truck Enthusiasts Forums
Old 08-25-2014, 10:52 AM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
This weekend I replaced the spark plugs on my sister's 2008 Expedition with the 5.4L engine. Hers is an early 2008 so it had the black boots and the "bad" spark plug setup. It also has 118K miles on the original plugs. Yikes. After seeing it mentioned on here in a few threads and after watching this video:
I decided to go with the impact method. It's not explained anywhere that I can find, but I kinda figured out that the reason this works is it does not give the seized plug time to get hot and expand in the head. You kinda sling the carbon off the plug and it's out before it can get stuck.
I did have her run a can of Seafoam in each tank for 3 tanks beforehand and I brought it into the shop hot, just like the video says to do. I went 7 for 8 and only broke 1. It was the second plug so I had to nut up and continue but got the other 6 out with no problem. The Lisle extraction tool worked perfectly and the stuck plug remnant came out fine.
I used a 1/2" impact on the front 3 plugs but I had to use a smaller 3/8" impact on the back plugs. On those I broke them loose first with a ratchet since the little impact isn't nearly as strong as the big one.
I used NAPA Nickel Anti-Seize and torqued the new Motorcraft plugs to 25 ft-lbs.
I recommend this method. It worked for me. I did break the one plug, but with such high mileage on the original plugs, I was pretty happy with that outcome.
Old 08-25-2014, 12:40 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
I use an impact to remove these plugs and might break one every 5-6 sets. Good job on removing the plugs.
Old 08-26-2014, 08:42 PM
TritonF150's Avatar
TritonF150 TritonF150 is offline
TritonF150 is starting off with a positive reputation.
Wow, I'm thinking of giving this a try, any negative effects to either the treads or head?? that video was impressive I know I can't be the only one who puckers on the thought of plugs.
Old 09-04-2014, 02:16 PM
jas88's Avatar
Not that I could tell. The new plugs threaded in easily and took the torque without stripping.
Old 09-04-2014, 06:59 PM
TritonF150's Avatar
OK thanks for the reply I'm still kicking this around I (believe) my plugs have been changed as I recently bought the trk but never hurts to do it so I know its done right
5.4l 3v Spark Plug Removal Instructions makuloco2000 1999 to 2016 Super Duty 56 11-30-2015 08:48 AM
3 Valve Spark Plugs / To Impact Or Not To Impact OneTon350 Modular V10 (6.8l) 14 11-06-2015 01:15 PM
4.6l 3v Broken Spark Plug Removal Method makuloco2000 Explorer, Sport Trac, Mountaineer & Aviator 4 02-02-2015 11:22 PM
5.4l 3v Broken Spark Plug Removal Method makuloco2000 2007 - 2014 Expedition & Navigator 4 01-31-2015 05:03 PM
Tackled the Sparkplugs (8 for 8!) jblac15 2004 - 2008 F150 21 10-21-2014 09:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
