Liftgate Won't Open- Gaining Entry and Repair
In this video I go over what is becoming more and more of an issue with this generation of Escapes due to the poor lift gate glass seal leaking rain water into the latch and electronics in the lift gate. I go over the cause, how to gain access, diagnosis, and of course repair.
How to remove and replace a bad liftgate switch
I have watched your great video on fixing the liftgate latch on an 09 XLT, but I have a bad liftgate latch switch on my 08 XLT. Cannot figure how to remove and replace it. Switch is in a plastic trim molding just below the window and above the license plate. Removed the four nuts from the studs that appear to come from the trim molding, but cannot move it. I don't want to break the molding, but can't figure out how to get the switch out without removing the trim molding. Ideas and help wanted...
Removing the plastic trim molding
As I mentioned in my earlier post, to access the liftgate latch SWITCH, the trim molding on the 2008 Escape that is between the license plate and the bottom of the rear window has to be removed. After removing the four nuts on studs from the molding, I cannot figure how to remove it without breaking the two plastic clips that also seem to be retaining it. Anyone with any thoughts would be much appreciated!!!!
You need to carefully pry the assembly loose to remove it. My '02 had a broken hatch handle.
If you mean the portion where the handles are, mine was held in place with the bolts and 2 sided foam tape as a sealant for weather. If I recall correctly the bottom pops out first.
brc777
1997 - 2003 F150
04-18-2018 12:17 AM
Marcos_M
1997-2006 Expedition & Navigator
12-29-2011 12:46 AM
Snowking
12-24-2007 12:43 PM
borland
02-29-2004 12:33 AM
