Gonna buy a Dana 60 SAS, what do I need to look for? - Ford Truck Enthusiasts Forums
Old 08-25-2014, 09:22 AM
SVTDriver97's Avatar
SVTDriver97 SVTDriver97 is online now
SVTDriver97 is gaining momentum as a positive member of FTE.
Hey guys,
I'm in the market for a Dana 60 SAS axle and i'm going to look at one this weekend.
Guy said it's already been sandblasted and painted. It's out of a '91 F350, it was before they used ball joints, so it's a king pin axle.
Those are the only pictures he sent me.
I'm a complete newbie when it comes to axles. I think I have Dana 50 in my '86 F250 and as long as the spring perches are 35" and it has 4.10's in it...it should work. Right?
I want to make sure that i'm not buying a complete POS, so what should I look for? Obviously cracks in the case, but is there a way to determine that the hubs work, and everything works as it should when it's out of the truck? Guy is charging me $950 to put 4.10's in it, (it has 3.54's in it now he says) If I were to buy it with the 3.54's in it now, he'll only charge me $850, which I still think is a little on the high side, but it's close to me, and I can get it.
What do you all think?
Old 08-25-2014, 11:16 AM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
The price is whatever the market will pay.
Kingpin 60's are desirable and he knows it.
$100 for a properly setup R&P swap seems like a good deal to me.
D50 came with supercab F250's, otherwise it would have to be ordered as part of a plow package.
Do your hubs come straight out like a can, or do they taper like a plastic cup?
Old 08-25-2014, 12:24 PM
They're like a plastic cub, start big at the rim, then get narrower towards the outside, and rounded on the end.
Old 08-25-2014, 12:42 PM
pedant
D44 HD like mine.
I don't have much advice other than the obvious.
If I were going to lift my 250 and/or run big tires That kingpin D60 would be first thing on my list.
I really haven't had major problems with my TTB front end, but it does take someone who knows WTH they are doing to align it right and it is expensive to service.
It is starting to tweak in reverse (again) so I suppose it is time for new pivot bushings.
Old 08-25-2014, 01:51 PM
See that's what i'm fearful of. The maintenance costs.
Right now, it's just barely starting to leak from the gasket on the drivers side arm. Ford in all of their wisdom had to bless us with these, so now if the gasket starts to leak, you gotta tear apart the whole front end just to rebuild it and then have something else fail on ya. My local shop charged me $300 in labor just to replace the seal, that's not including the alignment or any other parts. Then once that goes out, who knows what it'll take next.
No thanks. That's why I want to go this route.
Not too sure if lifting will be the way i'll take this thing in the future, but i'd like to have it available to me if the situation presents itself.
Is there anything in particular I should look for though? Rust in a certain area meaning anything, leaking seal to look for here or there, ya know? Any pointers.
Old 08-25-2014, 04:48 PM
Nothing Special's Avatar
Nothing Special Nothing Special is online now
Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.
$100 for a properly set up ring and pinion sounds like an unbelievably good deal to me. And I mean that. It doesn't sound believable. Are we sure it's not $850 for the axle and another $950 to swap the gears (total of $1800)? That would seem a little high, but a lot closer to reality.
Old 08-25-2014, 04:50 PM
dylansf23's Avatar
dylansf23 dylansf23 is offline
dylansf23 is gaining momentum as a positive member of FTE.
Honestly, I don't think there's much to look at? It's a solid piece of steel. Checks brakes? And anything not on the hard tube.
Old 08-25-2014, 05:21 PM
pedant
I don't know how to check for a bent axle or bad splines without pulling them.
That's about all I could think of going wrong unless the pins are worn out from lack of grease.
I pay $250 to have my guy set up a ring and pinion.
I supply the master set and the gears.
I break it in right and assume all responsibility.
If the guy already has gears lying around and knows what he's doing I can see him willing to swap it for a C-note.
It's sitting on the floor and probably dry right now anyhow.
Old 08-26-2014, 07:12 AM
Quote:
What i'm fearful of, is the guy doesn't know how to install them, that's why it's $100 more. Don't you have to set the lash, and do all kinds of weird stuff with special grease to set it up properly?
Old 08-26-2014, 07:54 AM
pedant
If the carrier is already set up and the gears are already broken in there shouldn't be any shimming.
Check the mesh with paste (or even regular zinc oxide) and be on your way.
It is not in the truck so there is no crawling around, pulling the wheels off or nasty hypoid to deal with.
$100 is a deal, but labor is a lot less when all he's doing is swapping the R&P on an axle that is offered as being in good shape already.
If it's so close to you maybe the guy will do it while you're there?
You seem inconfident in the deal.
What's up with that?
Old 08-26-2014, 11:47 AM
Damn near 1 grand for the whole deal when I really could use the money elsewhere.
My TTB is leaking right now, and rather than dealing with trying to fix the leak, take everything apart, pay to have it aligned, and all that jazz that goes along with it, i'd rather replace it with something that I would eventually end up replacing anyway. I'm debating if it's the right time to be doing this, and i'm leaning towards not. Because I don't have the time or money to pay to have someone install it and set it up for me for cheap. I'm actually going to focus on sandblasting the underside of the bed and the frame, and replacing the windshield instead.
Old 08-26-2014, 12:27 PM
CountryBumkin's Avatar
CountryBumkin CountryBumkin is online now
CountryBumkin has a good reputation on FTE.CountryBumkin has a good reputation on FTE.CountryBumkin has a good reputation on FTE.
If your TTB is working fine but just leaks a little - you'll save a bunch of money just resealing it. You don't need to realign the frontend if you put everything back the same way. You are not really changing alignment by removing the spindles and pulling the axles and/or differential. There may be different camber bushings between left and right sides but just mark them (mark toward front) and don't mix up the sides.
Swapping from a TTB to a straight axles is a lot more work than resealing what you have.
Old 08-26-2014, 01:05 PM
Has anyone ever made a write-up for doing a solid-axle swap? I can't seem to locate a "How-To" for it.
My mechanic is gonna charge me $300 in labor alone...not including getting it aligned, or any parts that may need to go into it. That was my justification for going to a straight axle swap, because I figured if i'm going to spend this much money anyway...let's get it done the right way!
I did just get it back from the shop yesterday, and he re-torqued all of the bolts on the cover to see if that helps. I still have yet to see if the leaking has slowed. It's not like it's pouring out, but it is enough to leave the diff wet, and a few drips on the ground when it's parked.
I was also thinking...what would a can of Trans-X or Bars stop leak do to a differential? Would it severely mess things up, or would it actually stop the leak you think?
Old 08-26-2014, 07:09 PM
dylansf23's Avatar
If it's just the cover, then take it off and put a new seal in it?
If it's just a few drops, the hell with it, let it leak but check it once a month or so.
Old 08-26-2014, 07:48 PM
pedant
If I was looking at a complete TTB overhaul @ $1,200+ I would jump all over a D60.
Does it come with a pitman arm too?
Hello...Sister of a 1960 F100 Owner Sanity Check Marfa 1957 - 1960 F100 & Larger F-Series Trucks 9 01-25-2017 03:39 AM
'48 ford F1 parts and fenders pricing F-1 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 09-01-2016 11:02 AM
1966 F100 Patina Finish Inline66 1961 - 1966 F-100 & Larger F-Series Trucks 27 07-16-2016 03:09 PM
Central PA Classic Auto Auction pics!! Nice 51 and 53! abe 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 07-15-2016 05:12 PM
Side draft setup! dylansf23 Ford Inline Six, 200, 250, 4.9L / 300 17 10-01-2015 05:29 PM
Tags
1986 f250, axle, dana 60
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
