1997 F-350 Turn Signal Problems - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-25-2014, 07:59 AM
BillJones BillJones is offline
BillJones is starting off with a positive reputation.
I am chasing an electrical issue with my 97 F-350. The rear lights have not worked properly in the several months that I have owned the truck. This weekend I took the flatbed off to fix it, and thought that I wouldtry to figure out the wiring problem.
My problem is that when I turn on the left turn signal, I get 12 volt on that wire and 8 volts on the wire for the right turn signal. It is the same for the right turn signal, 12volts on the right wire and 8 volts on the left wire.
The front signals do not have this issue, it is only with the rear of the truck. There is also a group of wires running to the rear of the truck for a trailer plug that appear to be factory wires. These wires mimic the same behavior as the wire for the truck lights.
Can anybody help shed some light on my situation?
Thanks,
Bill
Old 08-25-2014, 08:31 AM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Does it have LED lights on it ?
Old 08-25-2014, 08:49 AM
Quote:
No, it does not have any lights on it. The bed is sitting on a metal stand beside the truck.
Bill
Old 08-25-2014, 09:58 AM
Hussler's Avatar
Hussler Hussler is online now
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
Could be quite normal. PCM put out a voltage, through a pull up resistor, to monitor rear brake - turn signal functionality.
What is the original problem causing you to troubleshoot?
Old 08-25-2014, 10:18 AM
Hussler's Avatar
Here is a link describing the situation and why it does it ...
http://www.google.com/url?sa=t&rct=j...73612305,d.aWw
I would just attach the PDF however don't know how to do that.
Old 08-25-2014, 10:44 AM
The reason I removed the bed was that it must have lived it previous life in a Salt mine. It was very rust to the point that I didnt trust hooking a trailer to it. I have new CM flatbed waiting to go on the truck as soon as I get the frame rails painted.
Prior to removing the bed you could notice a faint hint of the opposite turn signal trying to illuminate when using the other sides turn light.
Your post makes he hopefull that it could be a small issue with grounding.
Bill
madpogue madpogue is online now
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Rather than attach the PDF, post the direct (no CIA-gle) link to it: http://www.ford-trucks.com/forums/at...chmentid=49079
FIRST thing to check is the center stop light in the cab roof.
Old 08-25-2014, 03:53 PM
The center stop light was the culprit. Thank you very much.
Bill
79 Ford truck instrument harness wiring guide John Rowe 1973 - 1979 F-100 & Larger F-Series Trucks 15 11-21-2016 10:13 AM
SERIOUS light issues old blue beast 1987 - 1996 F150 & Larger F-Series Trucks 3 08-05-2016 09:28 PM
Introduction and Clutch Question On 1946 2 Ton Craig46 1947 and Older Ford Trucks 35 12-19-2015 03:16 PM
Value Question jayzad 1973 - 1979 F-100 & Larger F-Series Trucks 0 02-27-2013 07:11 AM
Need a starting place for 6.0 Engine Issue ten.mile 1999 to 2016 Super Duty 2 12-11-2012 06:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
