Changing E4OD solenoid block connector
I have a '96 E350, 7.5L, E40D that is a transplant from a '97 E350. Approx 55,000 original miles on this tranny. Regular fluid changes. Use is my work truck, 80% in-town speeds and 20% highway speeds. I have been having subtle intermittent shifting issues. I unplgged the solenoid block connector on the passenger side of the tranny to clean it. Inspection of the bulkhead connector showed 5 of the 9 pins had corroded off, and remained embedded in the harness side of the connector. It must be changed. Do I need to replace the entire solenoid block, or can I remove and replace just the connector? I searched for a write-up on this repair, but could not find one. A link to the procedure would alleviate some anxiety on forging new territory. Thank you. Kirt
Good morning. As you said, Mark, the solenoid block replacement was a piece of cake. My work truck is back to shifting like new. Thank you again for coaching me. I am so thankful for this cite. Without it, I would be spending way more on vehicle repairs and I would not be enjoying my dentsides, like I do. Kirt
lincoln20012002
04-25-2009 05:03 AM
countryF150
10-10-2006 12:03 PM
