2008-2012 Ford Escape Expensive Receiver Drier Failures
Now while this may or may not be a repair you would attempt depending on your equipment, it is still one of those very good to know items lurking in your Escape just waiting to fail and then it gets real expensive! I personally own an Escape and replaced mine as even with my free labor and hefty parts discount it would still be a expensive job if it failed and destroyed the rest of the A/C system. Just an FYI for all Escape owners in case you already didn't know.
Thanks! I probably should get onto this this winter. High A/C use here, Texas.
How do I make sure I get an improved drier, and not just another original design one with the same inherent dessicant bag problem?
I assume there is a new part number for the improved one. Could you please tell us the new part number to get?
We had ours in under warranty, the cost of the job was more than the premium ESP package itself, well worth the investment on our end.
AS to symptoms, it depends on how bad it clogs, the first thing I noticed was the fans running full blast at startup, if the systems senses high pressure, it will bring the fans up high to try and protect the compressor. But by then it's too late. Full system replacement. The blockage was so bad, that sitting static after shutdown, I could not get my high side gauge coupler to seat.
What was replaced. I just read where a tech stated that he did one of these where ESP wouldn't cover replacement of the condenser and evaporator.
Hi Makuloco,
In case of the failure of Receiver Drier, which caused the debris fill up the entire AC system, what is the possible option to fix it, except replacing whole or most of AC system? Or, what are the least parts which have to be replaced, then rest can be kept?
Any comment on this?
Really appreciate if you can reply to me.
Regards,
Michael
Regards,
Michael
bigcrunch
04-04-2016 05:24 PM
reamer
02-01-2007 11:20 PM
