Please reply need help
Fuel rail. Truck will still not start, will try when I spray starting fluid down intake. I don't think my injectors are firing, i put my meter on the plug going to the injector on the driver side and it is getting power and ground as soon as I turn they key. Does anyone have a wiring diagram for the injectors? Anyone know what could cause it not to start if I have spark and fuel at rail? Please help, I have dumped thousands of dollars into this repair and have gone to 3 mechanics who could not fix it. It's a 1999 f250 with a v10, automatic. Could this be another bad pcm??
There was some cut up wires in the harness and I replaced all of them. I have now also pulled out all fuses that are not required to start the truck just to be safe. I'm getting voltage to the injectors now, I'm getting spark and the fuel pump is kicking on very briefly. I'm going to get a fuel pressure gauge tonight and test that. Is it possible that I might have a bad regulator/ fuel filter from sitting for 18 months during the electrical repair? What should the fuel pressure be?
Found some wires on the headlight switch rigged up, wires in door had been cut up by window rolling up and down. The first mechanic replaced the pcm 2x them said something about a short in the instrument cluster, them replaced the pcm again . It was with the first mechanic for 16 months, at that point I realized he would probly never get it running so I took it to 2 more mechanics who didn't rally seem to know what they were doing
shadetree2070
19
02-02-2011 03:08 PM
