Please reply need help - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 08-24-2014, 08:25 PM
Codyscee Codyscee is offline
Codyscee is starting off with a positive reputation.
I'm having huge issues with my truck. I've replaced the fuel pump, pcm (3times), all relays. I believe I have the fuel pump operating properly, it turns on for half a second at a time( only getting power from pcm for a half second) I'm getting decent pressure fuel
Old 08-24-2014, 08:33 PM
Fuel rail. Truck will still not start, will try when I spray starting fluid down intake. I don't think my injectors are firing, i put my meter on the plug going to the injector on the driver side and it is getting power and ground as soon as I turn they key. Does anyone have a wiring diagram for the injectors? Anyone know what could cause it not to start if I have spark and fuel at rail? Please help, I have dumped thousands of dollars into this repair and have gone to 3 mechanics who could not fix it. It's a 1999 f250 with a v10, automatic. Could this be another bad pcm??
Old 08-25-2014, 12:50 AM
350v10 350v10 is offline
350v10 is starting off with a positive reputation.
Have you checked the emergency shutoff switch behind the passenger side foot well? Check and see if the button is pushed down.
Old 08-25-2014, 06:42 AM
Yes, ohmed it out and it's sending power to pump. I manually tripped and reset it it just to make sure it was working properly.
Old 08-25-2014, 08:37 AM
JWA's Avatar
JWA JWA is online now
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Are you certain---CERTAIN I ask---that all the PCM grounds are intact and allowing current flow to ground when needed?
Frying three or more PCM's would have me looking very, very carefully at the chassis wiring harnesses.
Old 08-25-2014, 11:32 AM
toddb1 toddb1 is offline
toddb1 is starting off with a positive reputation.
its normal for it to only prime for a second, then drop to 6.5v or there about. Have you tried a fuel pump relay. Does your fuel pressure drop after you try to start it? Any codes?
Old 08-25-2014, 02:55 PM
There was some cut up wires in the harness and I replaced all of them. I have now also pulled out all fuses that are not required to start the truck just to be safe. I'm getting voltage to the injectors now, I'm getting spark and the fuel pump is kicking on very briefly. I'm going to get a fuel pressure gauge tonight and test that. Is it possible that I might have a bad regulator/ fuel filter from sitting for 18 months during the electrical repair? What should the fuel pressure be?
Old 08-25-2014, 03:35 PM
speakerfritz's Avatar
speakerfritz speakerfritz is online now
speakerfritz is gaining momentum as a positive member of FTE.speakerfritz is gaining momentum as a positive member of FTE.
Quote:
this is very important information to bring to light...why were the wires all cut up...what type of electrical repair takes 18 months...was the vehicle involved in a fire?
Old 08-25-2014, 03:42 PM
Found some wires on the headlight switch rigged up, wires in door had been cut up by window rolling up and down. The first mechanic replaced the pcm 2x them said something about a short in the instrument cluster, them replaced the pcm again . It was with the first mechanic for 16 months, at that point I realized he would probly never get it running so I took it to 2 more mechanics who didn't rally seem to know what they were doing
Old 08-26-2014, 07:36 PM
It looks like only half my coils are not getting power
Old 08-27-2014, 04:30 PM
zoenemo1's Avatar
zoenemo1 zoenemo1 is offline
zoenemo1 is starting off with a positive reputation.
did you replace the pcm power relay?
Old 08-27-2014, 04:39 PM
zoenemo1's Avatar
also the pcm controls the ground side of your coils so you should have 12volts key on engine off fuel pressure key on engine off 35-45
2000 Excursion 6.8L Fuel Pump Problem JDSIMPSON55 Excursion - King of SUVs 4 01-11-2017 06:53 PM
New F-350 1997 7.5 got a electrical issue. Torch force 1987 - 1996 F150 & Larger F-Series Trucks 11 11-01-2016 06:31 PM
1980 f100 EFI swap troubles Larry Heath Wheeler 1987 - 1996 F150 & Larger F-Series Trucks 16 10-15-2015 11:06 AM
1995 f350 5.8 starts no PCM and no start with PCM? ifiteverruns 1987 - 1996 F150 & Larger F-Series Trucks 22 03-30-2015 12:54 PM
2000 F350 cranks ok, intermittent no start solved. mikelbx01 Modular V10 (6.8l) 0 07-14-2014 01:50 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
