CARB SPRAYING FUEL - Ford Truck Enthusiasts Forums
CARB SPRAYING FUEL
Old 08-24-2014, 06:07 PM
mgerdau mgerdau is offline
mgerdau is starting off with a positive reputation.
CARB SPRAYING FUEL
I have a C 3 TF H 2bbl Carb I rebuilt it with a kit from Napa. I'm thinking the float may not be set right. If I accelerate a fine mist of fuel blows out of the carb. Looking into the throat I can see a lot of fuel, well its very wet.
Also, I've been checking the forum for adjusting procedures, all I've found so far are discussions on 2150's or 2100's. I didn't notice a vacuum port to attach a gauge to so I've been just adjusting the air/fuel mixture by ear and watching the tach. I was wondering if I should detach the line that goes to the distributor and check the vacuum there.
Any help would be appreciated.
Thanks!
Old 08-24-2014, 09:37 PM
FortyNiner's Avatar
FortyNiner FortyNiner is offline
FortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to behold
How does the truck run?
Old 08-24-2014, 11:53 PM
Quote:
Runs ok a little hesitant when accelerating.
I did check the float and I had it a little high. Reset that at 21/32nd.
I had kept the Napa rebuild kit there were two sets of instructions in it. One set for a Model F2 and another set for a 2100-D.
In the rebuild kit I found the rubber check valve that everyone talks about pulling through from the float bowl side. So I checked to see if maybe I forgot to put that in. What I found was a metal seat for the spring with a check ball in the top that was held in place with a screw from the top.
I also found I had the over ride rod in the wrong holes so put the rod in the inside hole and then in the 1st hole in the back. Couldn't get the pump adjust to 5/32, best I could do was 3/32.
I did put my vacuum gauge on the vacuum line that goes to the distributor. The vacuum fluctuated from 5 to 0, so I must have a vacuum leak somewhere. I had checked by spraying WD40 around the base of the carburetor and everywhere else but no rise in RPM's.
But sure seems to have too much fuel going into the carb.
Old 08-25-2014, 01:54 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
WD40 does not readily burn, so it is a poor product to try to find if you have a vacuum leak with. (in fact it's a poor product for most of what people try to use it for except to keep metal from rusting) Try using starting fluid.
Old 08-25-2014, 03:18 PM
yamagrant's Avatar
yamagrant yamagrant is offline
yamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputation
Quote:
I use WD40 for starting snowmobiles that have sat all summer. I remove the plug's and giver a healthy dose in each cylinder, and they fire and run till the fuel pump kicks in. Spray some on the ground and light it. Seems to burn readily for me. In the trade I used the acetylene torch, gas only, on very low to chk for vacuum leaks. I don't have my oxy/ace anymore, and find WD40 will work just fine. I find Starting fluid and carb cleaner too volatile. good luck.
Old 08-25-2014, 04:48 PM
fladoodle's Avatar
fladoodle fladoodle is offline
fladoodle is gaining momentum as a positive member of FTE.fladoodle is gaining momentum as a positive member of FTE.
Quote:
I seem to remember someone telling me that WD40s old formula used to be a really good starting fluid for diesel engines and that they reformulated it at some point, (probably health/safety type reasons,) and that the new formula was not as volatile(?) or something else that made it not work as well.
Old 08-25-2014, 06:12 PM
yamagrant's Avatar
Quote:
The can in my shed is about 5yrs old. I use it every fall and it works like a charm.
Old 08-25-2014, 07:42 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
An unlit propane torch works well too.
Timing advance not working, rebuilt carb not responding to adjustment. lvin4jc 1967 - 1972 F-100 & Larger F-Series Trucks 27 01-02-2017 06:10 PM
4.9 (Carb) Running VERY lean bg_ 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 02-26-2015 05:31 PM
Where else to check for vacuum leaks tomwhatley 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-20-2014 11:39 AM
Holley 4160 won't idle below 900 wyckedcombo17 1973 - 1979 F-100 & Larger F-Series Trucks 11 08-15-2014 07:25 AM
My economic 390 project 0ldman 1973 - 1979 F-100 & Larger F-Series Trucks 29 07-07-2014 10:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
