Starting 390 FE - Ford Truck Enthusiasts Forums
Starting 390 FE
Old 08-24-2014, 04:23 PM
Don Vito Don Vito is offline
Don Vito has a great reputation on FTE.Don Vito has a great reputation on FTE.Don Vito has a great reputation on FTE.Don Vito has a great reputation on FTE.Don Vito has a great reputation on FTE.
Starting 390 FE
so I bought this 56 f100 project truck that has a 390 fe & c6, the cab comes off on Tuesday and goes to the media blaster so I think it may be a good time to see if the 390 actually runs or not, which will be a factor in whether I keep it or go with ford must 5.0 and AOD, my question is, as there is no wiring what so ever, can I just connect a couple leads to the starter and a little gas in the carb, just to see if it has any life? Or is there something else I need to do?
Thanks in advance
Old 08-24-2014, 05:20 PM
dmack91's Avatar
dmack91 dmack91 is offline
dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.
It will depend on how the ignition is set up. Post some pics and someone may be able to help. At a minimum, you will need to run a power wire to the coil and another wire from the dizzy to the coil. If it has an electronic distributor, it will need a control box wired in too. If points and condenser, it will be basic.
Also, I would pull the valve covers and prime the oil pump until you see oil (new oil and filter too) coming up through the pushrods to the rockers.
390FE upgrades greentruck72 1973 - 1979 F-100 & Larger F-Series Trucks 25 11-20-2015 08:24 AM
timing chain problems- 390 FE greentruck72 1973 - 1979 F-100 & Larger F-Series Trucks 6 08-04-2015 05:29 PM
Bronco 2 390FE swap? greentruck72 Bronco II 5 03-13-2015 10:16 AM
motor 360 or 390 montrealford 1973 - 1979 F-100 & Larger F-Series Trucks 11 02-07-2015 05:51 PM
FE 390 Information & Facts (Comp. ratio, compatible auto trannys?? etc.) 72f100sc 1967 - 1972 F-100 & Larger F-Series Trucks 10 12-27-2012 08:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
