dentside 4x4 dually?
#31
with all do respect, I believe you need the education...and start with some factual literature please!
From the 1978 shop manual volume1 group15 axles and driveshafts
#33
No.
It's in my 1978 and 1979 ford truck shop manuals. Factory with Rockwells front and rear.
1978 truck shop manual. Volume 1 chassis. It's in part 14-22 front suspension.
Also, there is a sales brochure entitled bronco's big brother: f600 4x4.
You go educate yourself, all these trucks use Rockwell units not MH axles. Those were installed on the bigger trucks.
Ford used a Rockwell t-223-c1 transfer case and an f106 front axle.
#35
#36
Remaining calm!
MH and Ford were together long before '59!
Napco wasn't the 1st to convert Fords, but yes, Ford did also use Napco and those equipped had Napco badges!
I don't care if it's in your service manual or in a brochure, it's still a Marmon-Herrington conversion. When Napco made the first 4x4 systems for the Ford pickup in 1959, Ford never called their trucks a Napco 4x4 but, the Ford 4x4 system was still shown in all of the Ford service manuals. BTW, Marmon-Herrington is the name of the conversion company, not a brand of axles. Marmon-Herrington is still in business, give them a call if you don't believe me. Once again, go educate yourself.
#37
on
And stop that.
#38
#39
Well, all I can say is how I remember it:
No F-350 4X4's until 1979, and even then only available as a SRW pickup.
No 460's in 4X4's until 1983.
No dually's available 'factory' before 1980.
If you wanted a crew cab dually 4X4, you had to see your Chevy or GMC dealer.
F-600 4X4's were available from the factory with Rockwell axles starting in the late 70's, at least by 1978.
Marmon-Herrington has done 4X4 conversions of light and medium duty Fords since the 1940's. They do make their own axles, usually 'M-H' is cast in the front hubs.
Coleman also did 4X4 conversions of Ford medium and heavy trucks.
Napco did some Ford conversions in the 50's, but was more known for Chevy, GMC, and Studebaker conversions.
Bulldawg1081
10-17-2012 12:18 PM
ronnie pettit
20
07-23-2010 08:29 PM
