53 progress update with pics - Ford Truck Enthusiasts Forums
Old 08-24-2014, 02:31 PM
71mach351's Avatar
71mach351 71mach351 is offline
71mach351 is starting off with a positive reputation.
The 10 year plan in now nearing the end of year 5. So far so good. So far I've done cab corners, rocker, 1/2 a floor, door bottoms. Welded body seams. Shaved front valance of the directionals. Front disk brake kit. Hanging power brake kit. All new brake lines and gas lines? New gauges. All new wiring. Rebuilt 351w. Modified shifter to work with fmx tranny. Solid side window kit in progress. New spring bushings and extra leaf removal. Corvette tail lights. Under bed tank.
Still needs a complete new bed and interior. But for now it runs, drives and stops. Enjoy!
Old 08-24-2014, 04:34 PM
r_reed's Avatar
r_reed r_reed is offline
r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.
looks nice, you have a lot more patience than i do. great work. it will be a fine truck.
Finally looking like a truck again 71mach351 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 10-05-2016 12:41 PM
Low budget carpet 71mach351 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 09-14-2015 05:59 PM
Door handle modification 71mach351 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 05-03-2015 05:29 PM
Another seat option 71mach351 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 10-21-2014 07:24 PM
Found a 53 cab for my 56 71mach351 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 10-15-2010 05:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
