Where's Ford's best inline six?
The title of this sub-forum is, "Ford Inline Six, 200, 250, 4.9/300." Of course, this leaves out some others, but the 240, the first "Big Six," maybe ought to have been mentioned in the title, because (my opinion) it was Ford's best-ever inline six.
As compared with the 300, which was basically a stroked 240, the smaller engine had better rod angularity (better rod-length-to-stroke ratio) so it was a little more mechanically-efficient, a little quieter, and had less tendency to break pistons. The small valves that limit power in the Big Sixes are slightly less restrictive to the 240. Being a pre-smog-era engine, the 240 had a better combustion chamber, although the swirl head of the EFI 300s can be good for a street car that needs good fuel efficiency (seems to be some controversy as to whether the swirl head is prone to cracking, however).
In short, if all you need is 240 inches, and I found that was plenty for my early van, the 240 should be your first choice (okay, unless you have the cash to get an Aussie 250 or the aftermarket aluminum head for an American 250). Add a modern ignition, upgrade the intake and exhaust, and you have the Chev 327 of inline sixes, a happy little engine.
Brian's 48
12-02-2011 06:05 PM
ConnertuckyF150
12-05-2005 01:27 PM
91paint pealer
09-11-2002 12:17 AM
OLD67Weber
04-15-2000 06:21 AM
