Help! 6 Banger will not start!
Old 08-24-2014, 06:26 PM
fordf348's Avatar
fordf348
fordf348 is offline
Have you tried starting it with a 12 volt battery?
Old 08-24-2014, 08:40 PM
FortyNiner's Avatar
FortyNiner
FortyNiner is online now
Originally Posted by Tedster9
Orange/red spark = Not Good
Remember, that's in the open air, too. It's under compression and load that an ignition has to perform. What you want to see is a nice fat bluish spark with an audible "snap" to it. You could try cleaning up your grounding points and connections, and the little jumper wire on the dizzy breaker plate.
What Tedster said.
Besides the disty attachment issue, your connections all need to be checked - that includes the coil and plug wires.
Old 08-24-2014, 09:02 PM
Skalywag's Avatar
Skalywag
Skalywag is offline
If you have flooded it lately, you may have washed all of the oil from the piston rings. If that is the case, try putting some engine oil in each cylinder. It has worked for me a number of times. I know it sounds lame, but you are about out of options. Just a thought.
lawsonej
05-31-2016 07:40 AM
ndmccann
10-08-2012 01:11 PM
Murph2006
02-22-2008 07:54 PM
DSalmon
01-24-2004 09:56 PM
steve83
1978 - 1996 Big Bronco
12-19-2002 04:12 PM
Quick Reply: Help! 6 Banger will not start!
