Fuel Filler Neck
Fuel Filler Neck
Hello guys(and ladies),
I am having some trouble finding a fuel filler neck for the rear tank of a 1979 f150 4x4. Rock auto, LMC and Bronco Graveyard don't have the part listed. They have pretty much everything but the metal filler neck. Mine has rusted out and dumps half of what I put in onto the ground. The PO looks to have covered it in POR15 as a temporary fisame as the gas tank).
Does anyone know where I can order of these? For those of you with a master parts catalog, are there any NOS parts left in the USA? Or anyone outside of the rust belt willing to pull a good part?
You mean this...the one next to the one with the black plastic piece still attached? I am still OTR till the end of Sept....
MTS COMPANY, L.C. - Ford Pickup fuel tanks
1973-79 Ford Pickup Truck Fuel Tank
Fuel Filler Necks from Fuelpumpwholesale.com
Those are the exact parts I need! However the websites did not pull up any results. I am tempted to weld and fabricate something now that you mention it. Possibly use some exhaust tubing of the same size if the rust is bad enough. Or just weld in a patch panel for where the rust has come through the metal completely.
Check these guys out. They specialize in older 4x4's and hard to find parts. I got a set of steering knuckles from them once for my 78 f150. And they were like brand new from a 30 year old truck. http://www.drivenautoparts.com/ They may have what you need.
I have been unsuccessful in finding a repop filler neck for the rear tank. The front tank was easy enough to find. I called the filler neck website number and asked them. They did not have any at the current time, but said they would within the next few weeks. Further inspection will decide if I can wait for that, or if I need to fabricate something on my own. My best guess is that I will have exhaust tube bent and a new lock ring welded on to fit the gas cap. Thanks for the help guys!
muddyoldford
18
05-29-2020 08:07 AM
Bukiman
13
12-26-2011 12:36 PM
disneyd
02-01-2008 04:15 PM
