04 vs. 06 F250 XLT?
04 vs. 06 F250 XLT?
Hello all - I am looking for a truck to use for farm work, but no major hauling. Currently narrowed down to two F250's - a 2004 with about 50k miles, OR AN 06 with 78k miles. In all other respects, they are essentially the same - 4WD, long bed, gas-powered. Any insights for me? Thanks very much.
My 02 F250XLT was totaled in Hurricane Charley (I had only made 21 payments ) and I got an identically equipped 05 as the replacement.
The two trucks are very different, as the Super Duties got some major enhancements in 05:
- the V10 increased about 50hp (went to 3 valves, improved intake & exhaust greatly, etc)
- frame much stronger due to thicker steel & improved design
- larger brakes with larger wheels to fit them
- various increases in suspension specs
- GVWR increased about 1,000 lbs to 9600 lbs
- 4spd auto replaced with 5spd with tow/haul previously only available for diesels
basically they went through and beefed up the truck in just about every area.
Identically equipped, my 02 was a great truck but the 05 is an awesomer truck
I'm pretty sure the '05 was the first year with the 5-spd auto in the gas trucks. It is a great tranny. Built-in brake controller also? As was said the '05+ is beefier in many ways. The '05+ 5.4 also has a nice bump in horsepower due to the 3V vs the pre-'05 2V 5.4. I would lean to the '06 all things being equal. ( The mileage difference isn't much of a factor in this case.
99-15 SRW SDs have a 8x170mm bolt pattern
99-04 450/550s had 8x225mm
05-08 F-350 DRW had 8x200mm
05-08 F-450/550 have 10x225mm
99-02 used 14mmx2.0 studs
03+ used 14mmx1.5 studs
EconoBob
02-09-2005 05:18 PM
