Heater Help - Ford Truck Enthusiasts Forums
Heater Help
Old 08-24-2014, 10:16 AM
flatheadkeith's Avatar
flatheadkeith flatheadkeith is offline
flatheadkeith is starting off with a positive reputation.
Heater Help
Ok guys...I am stumped on this one...I have a 49 F1 with the recirculating heater in it. I have rebuilt the heater, with the exception of the heater core. I cannot seem to find one. I searched the forum as best I could, but could not find any answers. I looked in the parts book, and it appears that the part I need is 8C 18476-A. I have been searching for days, and can't find the part. Does anyone know where to buy this part? It is a different part number than the fresh air heater, and that one I can find everywhere. Any help would be appreciated.
Old 08-24-2014, 11:12 AM
EffieTrucker's Avatar
EffieTrucker EffieTrucker is offline
Kentucky Chapter Member
EffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to behold
A good radiator shop should be able to rebuild the heater core.
I had mine done locally for $180. That might seem pricy, but like you I couldn't find a replacement anywhere.
Old 08-24-2014, 11:30 AM
FortyNiner's Avatar
FortyNiner FortyNiner is online now
FortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to behold
Contact firstrider, I'm sure he can help.
Old 08-24-2014, 03:01 PM
blue_cloud blue_cloud is offline
blue_cloud is starting off with a positive reputation.
Honestly guys I'd check with a good NAPA store, as a previous store owner, I can tell you that if you get a decent counter guy there may be help there. They have an illustration book with photos and dimensions of heater cores, among other parts, you may not find one listed for the exact application buy you probably will find something with dimensions that will work. NAPA is a great source, it just depends on the counter guy.
Old 08-24-2014, 06:12 PM
firstrider's Avatar
firstrider firstrider is offline
firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.
This core is not available . Believe me I have searched . Best bet is to have it rebuilt . Some times one must suck it up & bite the bullet . Useable heater cores are the draw back on the heater restos . Have a few good ones & a stack of bad cores .Keep them for useable tanks & tubes . Good luck .
Old 08-24-2014, 06:42 PM
Quote:
firstrider,
Glad you chimed in! The core I had seems to be in good shape. I looked on the bottom and it is stamped 8/3/95, but appears to be in great shape. I usually like to replace them while they are out, but I inspected it to be safe. I put it in a bucket of water and put 12# of air in it. Bubbles came out around the output tube. There is a spot that was soldered there, and it was leaking a bit. I am going to try to braze it tomorrow, but I will take it to a radiator shop if i cant get it right away. I don't want to mess it up any more than it is. Now that I know it is rare, I will keep it on my watch list for parts. If I see one, I will rescue it. Thanks for the help!
1978 F 7000 heater switch resistor mjsnodgrass Large Truck 2 08-19-2016 09:20 PM
64 F100 Heater Modification/ Update? CSmalley64 1961 - 1966 F-100 & Larger F-Series Trucks 9 11-18-2015 09:06 AM
heater hose part number needed dieselsubmariner 1994.5 - 1997 7.3L Power Stroke Diesel 10 09-17-2013 09:50 PM
56' F100 heater ? tigger4u44 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 09-19-2009 08:02 PM
Highout put heater F250army45d 1973 - 1979 F-100 & Larger F-Series Trucks 34 11-28-2008 12:33 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
