any known trouble areas to look for..... - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-24-2014, 08:11 AM
jasonw1976 jasonw1976 is offline
jasonw1976 is starting off with a positive reputation.
On an 06 F250 V10 6sp 4x4 crew cab, my kids are getting older so getting rid of the excursion and have been looking at 250's, I found a real clean 06 with 110xxx, everything looks copacetic and it drives and rides nice, it has a bully dog GT dohicky on it for keeping tabs on the engine, the owner says, and it also has a tuner from SCT by 5 star I believe...... Are there any major issues with the v10 and stick combo, or any other areas I should check.
thanx in advance for your input!
Old 08-24-2014, 10:55 AM
asdrew's Avatar
asdrew asdrew is offline
asdrew is gaining momentum as a positive member of FTE.
I love my 05 F250 V10 5sp auto 2wd crew cab, just plan on buying a lot of gas.
Old 08-24-2014, 11:35 AM
MDSuperDuty's Avatar
MDSuperDuty MDSuperDuty is offline
MDSuperDuty is a splendid one to beholdMDSuperDuty is a splendid one to beholdMDSuperDuty is a splendid one to beholdMDSuperDuty is a splendid one to beholdMDSuperDuty is a splendid one to beholdMDSuperDuty is a splendid one to beholdMDSuperDuty is a splendid one to behold
Have the plugs been changed? They tend to get stuck in the head and can break upon removal. Well known issue with tools and instructions for removal available.
Exhaust manifold studs can rust/rot off depending on if the truck sees corrosion filled roads.
Then just the usual brakes, u-joints, tires, and other wearable items.
Old 08-24-2014, 01:31 PM
Yeah I've read up on the plugs not sure if these have been changed, I normally do most of my own maintenance, but I have a very competent mechanic that has taken good care of my v10 excursion so he will prolly be doing the plugs for me lol, he did the manifolds on my ex for me...... I was most curious about the tranny and engine combo, I like the idea of the stick and hope it holds up..... Thank you for the responses so far.....
Old 08-24-2014, 03:03 PM
I'm sure the 6 speed manual is heavy duty enough for whatever you throw at it.
Yea I'll be getting someone else to do my plug change. I do nearly everything myself but that is a task I just don't even want to bother with knowing the issue. Rather find someone who has done a bunch and let them at it. Worth the money for the reduced possible headache.
Old 08-24-2014, 06:16 PM
speakerfritz's Avatar
speakerfritz speakerfritz is offline
speakerfritz is gaining momentum as a positive member of FTE.speakerfritz is gaining momentum as a positive member of FTE.
just google 2006 f-250 problems, ford v-10 problems, ford 6.8 problems, etc. you will get an earful.....but the question is...does all that really matter....buy the truck and deal with any issues you encounter.
Old 08-25-2014, 08:51 AM
nstueve's Avatar
nstueve nstueve is offline
nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.
Quote:
The tranny is a 6spd german made transmission commonly called a ZF. Mostly b/c people can't pronounce Zahnradfabrik Friedrichshafen.
good read on transmission here...
http://www.ford-trucks.com/forums/56...al-tranny.html
Buying an 06 F250 with a V10 Boneman03 Modular V10 (6.8l) 5 11-18-2015 12:56 PM
06 F-250 Vinford Modular V10 (6.8l) 12 12-20-2014 08:45 AM
getting a factory sirius tuner for 06 250??? rickauf Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 1 07-04-2007 01:37 PM
F250 V10 Loaded Vs. Expedition Eddie Bauer THUMPBIRD99 Car/truck Buying Advice 6 01-21-2006 08:20 PM
Looking @ 05 F 250 what engine V -10 or 6.0 PSD gdb1960 1999 to 2016 Super Duty 23 10-31-2004 09:57 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
