1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
DIY transmission fluid exchange write up
Old 07-30-2014, 11:27 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
kudos to "greasyfingers" on thedieselstop forum for posting.
has anyone tried this DIY transmission fluid exchange
http://www.google.com/url?sa=t&rct=j...92vC6EK109XFvw
Old 07-30-2014, 11:54 AM
CollinsCD's Avatar
CollinsCD
CollinsCD is offline
Nice write up but not sure I want to go to all the trouble of trying to build this rig for changing out my fluid. Plus, I have very limited welding experience especially on propane tanks.
Old 07-30-2014, 01:43 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
It's a homemade heated flush machine. Cool!
Old 07-30-2014, 04:42 PM
BossGasser's Avatar
BossGasser
BossGasser is offline
It is a really good idea!!
Although I would use a new vessel of some kind not one that is contaminated. I wouldn't run LPG residue through my tranny.
Old 07-30-2014, 04:53 PM
Mark Kovalsky
I did see one thing I disagree with in his procedure. He says to start the truck and let it run until both the engine and trans gauges are in the middle. This will only guarantee that the trans is above 50F, nowhere near warm enough to do this procedure even with a heated machine. The truck needs to be driven, and possibly with the trans cooler covered with cardboard to get the trans warmed up.
Old 08-22-2014, 05:39 AM
redford's Avatar
redford
redford is online now
Received 1,562 Likes on 910 Posts
My local dealer charges $170 for a Torqshift transmission flush. I'm not sure it's worth the trouble of building the device.
Old 08-22-2014, 07:34 AM
Number21's Avatar
Number21
Number21 is offline
If you can't build something like that for less than $170 you lose your google rights. Propane tank is $30 brand new if you can't handle a used one. Heater element is $20. Surely the other crap can be put together for less than $120. Even if you had to pay a guy to weld it that shouldn't cost much. Honestly I probably have 90% of that crap laying around the shop.
Of course the real savings comes when you do it more than once. And the fact that I won't take my truck to the dealer for anything out of principle alone...
Old 08-22-2014, 09:48 AM
droldsmorland's Avatar
droldsmorland
droldsmorland is offline
Or drain, drop the pan, clean off magnet, re install pan, refill. Drive 10 miles drain again and refill. $75 of fluid. Of course this will work for a standard service change interval not a trans with a grossly over due fluid change or heavy contamination. Still $170 isnt all that bad...IF you can find a dealer with the heated flusher.
Old 08-22-2014, 06:22 PM
Number21's Avatar
Number21
Number21 is offline
If you do this, you've changed half the fluid if you are lucky. Take half of that used ATF that comes out and mix it with half a new quart. It will still be very dirty, and that's what's left in your trans. I see no reason to bother taking the pan off if that's all you are going to do, the magnet does not need to be cleaned regularly.
If you've kept your trans clean with regular drains/fills from the pan you probably don't need to worry about this. If you've let your fluid get dirty, or, bought a truck that is dirty, just draining the pan will take many many cycles to actually make the fluid clean.
Old 08-22-2014, 06:33 PM
Tom's Avatar
Tom
Tom is online now
I really like the concept, but I don't like the lack of precision for the fluid being pumped back in.
Would you be able to set up a sealed recovery tank that you plumb the old fluid into. Connect a vent line to the top of the tank and run it to the top of the new fluid tank. As old fluid is pumped into the tank from the transmission the displaced air would flow through the line to the new fluid tank and build pressure. That pressure would force new fluid back through the return line and back into the transmission. If there were no leaks the exact amount of fluid that was pumped out of the transmission would be pumped back in, assuming of course the temperatures of the fluids were the same.
What do you guys think?
Old 08-22-2014, 06:38 PM
Number21's Avatar
Number21
Number21 is offline
I think that's how the commercial machines work. I've wondered if you could modify a water pressure tank with a bladder inside like you would use for a well. Not sure if it could take the heat...
Old 08-25-2014, 07:25 AM
droldsmorland
That is more or less what my post suggests.
Shadowrider123
09-12-2019 01:35 PM
dirty ernie
06-14-2008 06:54 PM
ford390gashog
Oil & Lubrication
07-05-2004 09:15 PM
Quick Reply: DIY transmission fluid exchange write up
