Dropped Valve - Ford Truck Enthusiasts Forums
Dropped Valve
Old 08-24-2014, 08:43 AM
erwatt erwatt is offline
erwatt is starting off with a positive reputation.
Dropped Valve
I have a 2000 Excursion with just over 200K miles. A few years back the engine started making a lot of noise and running so rough that it could not be driven. I parked it in the yard and it's been sitting ever since. This weekend I pulled the valve covers and discovered I had dropped a valve. Yes there is a big hole in the piston but it doesn't appear to have damaged the cylinder walls. I don't know if either valve seat was damaged. I wanted to pull the head (passenger side) to get a full assessment of the damage. I'm not sure if it's possible to get to all the head bolts without either pulling the engine or at a minimum of loosening the engine mounts and shifting the engine. Advice on which path to take would be appreciated.
Tks!
Old 08-24-2014, 05:37 PM
Restlesswildman Restlesswildman is offline
Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.
It is possible, others have done it.
It would be just as easy to remove the engine from the front and set it on the floor and work on it.
Start with the front bumper, grill and just keep working backwards. Fenders and hood and transmission stay in place.
Old 08-24-2014, 11:43 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
It would help to know what engine you have, since you don't have it listed.
Stewart
Old 08-25-2014, 01:15 AM
Apocalypse's Avatar
Apocalypse Apocalypse is offline
Apocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputation
Where are you located? Finish your profile
Old 08-25-2014, 07:10 AM
Ooops
Guess I forgot one important detail - the engine is the 6.8L V10.
Old 08-26-2014, 02:58 AM
Stewart_H's Avatar
Quote:
Thank you.
Sending this off to the V10 forum where they can get you all squared away.
Stewart
Old 08-28-2014, 09:33 PM
speakerfritz's Avatar
speakerfritz speakerfritz is offline
speakerfritz is gaining momentum as a positive member of FTE.speakerfritz is gaining momentum as a positive member of FTE.
hole in piston means metal fragments in the oil sump. oil pump is designed to protect the oil filter so it is likely there is metal chip damage .
I read somewhere you can not pull the oil pan with out removing the engine and with out the oil pan out you will not be able to replace the piston with the hole in it.
also, I don't want to sound like an a$#, but last year I traded in a 2000 expedition with 70k miles on it which had a 1700 set of 22 inch rims and only got 1500 for it and traded in a 2001 navigator with 85k miles on it and got 3000. so not sure if I would spend a whole lot of time and money on repairing a 14 year old vehicle with 200k miles....might be better to donate to iron lung or something and get a write off.
Old 08-28-2014, 09:53 PM
rvpuller's Avatar
rvpuller rvpuller is online now
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
That old and hole in piston I would look for a salvage yard motor, 2000 to 2004 will work.
Denny
2002 6.8L V10 engine replacement abqgolfer 1999 to 2016 Super Duty 2 05-04-2016 06:08 AM
drop washer fluid hose in cylinder ! pechroc1 1999 - 2003 7.3L Power Stroke Diesel 65 11-16-2015 02:28 PM
Fence Row 96 F-250 NashFord 1987 - 1996 F150 & Larger F-Series Trucks 12 10-21-2015 11:00 PM
Valve job or long block? 80,000 miles bbells2009 2004 - 2008 F150 3 02-27-2015 09:29 PM
Valve stem guide damage FordOwnerJoey Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 11-14-2014 07:04 PM
Tags
dropped valve, removing head
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
