4.2L INFO - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
4.2L INFO
Old 08-24-2014, 07:08 AM
MRPERSONALITY MRPERSONALITY is offline
MRPERSONALITY is starting off with a positive reputation.
4.2L INFO
Heya mates, so been looking into all mechanicals on my F250 and slowly redoing and attending to things, so now I want to replace injectors BUT aint buying from Ford here in South Africa (to dam pricy) but read using their part number It uses a bosch system so can anyone help on this as well as the diesel pump. thanks again
Old 08-24-2014, 08:51 AM
Aussie BrianB's Avatar
Aussie BrianB Aussie BrianB is online now
Aussie BrianB has a good reputation on FTE.Aussie BrianB has a good reputation on FTE.
Mr Personality,
G'day from Australia.
We have the same problem here and have to source our parts
from the US.
Even with freight it's still cheaper than local prices and there
is very little that is even available here.
Don't know about the 4.2 motors, they are pretty much
all 7.3 litre here.
You could try these guys,
RockAuto Parts Catalog
Discount Auto Parts Online -- PartsGeek.com - Domestic & Import Auto Parts Warehouse
Truck Parts & Truck Accessories for Chevy, GMC, Ford & Dodge Trucks | LMCTruck.com
Best of luck.
Old 08-25-2014, 12:40 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
Is there any reason you want to replace the injectors? Is there an issue?
If there are any issues, typically a diesel like yours with mechanical injection can have the injectors rebuilt and balanced. Any reputable diesel workshop that has a good knowledge of injection pumps can do this, and the cost is may be cheaper than new injectors.
However, I believe the Bosch part number for injectors on these is 0 432 193 731, there are also MWM and VW part numbers that give you the same injector. I know a 4cyl version of the 4.2 was available in Europe, it may possibly have been sold in South Africa too?
If your Ford dealer gives you this part number for the injectors: BF9T 9E527 BA - they should be right.
VW Lt 28 35 46 MK2 TDI Bosch Diesel Nozzle Fuel Injector 2 8 4 2L 1997 2006 | eBay
Old 08-25-2014, 01:09 PM
no reason at all, just thought maybe to do it, it does jerk sometimes at full throttle. thought to replace them after 150 000km
Old 08-25-2014, 01:51 PM
Unless you often have ****ty fuel, I wouldn't bother.
Mechanical injectors like those should go 300k or longer between rebuilds/replacements with good fuel (and assuming you aren't throwing smoke)
If truck stumbles at WOT, it typically means that the injection pump isn't getting enough fuel, or its getting a small amount of air sucked into the system.
Possible causes could be a failing lift pump, blocked fuel filter, or a slight air leak in one of the fuel lines.
Old 08-26-2014, 07:07 AM
nope the fuel I use is 50ppm or 10ppm and change fuel filter every 5000km, suppose over kill. thank for the other advise I will now give the lines once over as well and leave injectors for now. my F250 is my princess so doesn't really work only tows my jetski
Old 08-31-2014, 07:14 AM
what about those Rain curtains in the doors where could I get those, Ford here in rsa say don't have part number
52 Ford COE Panels Hughmullersa 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 04-20-2016 12:49 AM
46 Ford Chassis Hughmullersa 1947 and Older Ford Trucks 6 03-12-2016 09:58 AM
Africa Mike MikeIM New Member Introductions 3 01-01-2015 02:13 AM
Throttle sticks on my 1989 F150 V8 texan 1987 - 1996 F150 & Larger F-Series Trucks 8 10-13-2014 06:59 PM
54 F100 - Total Fibreglass and dual diff Heinrich Enslin 1948 - 1956 F1, F100 & Larger F-Series Trucks 40 09-25-2014 05:52 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
