Petronix I.E. - Ford Truck Enthusiasts Forums
Petronix I.E.
Old 08-24-2014, 05:14 AM
230thdratsab 230thdratsab is offline
230thdratsab is starting off with a positive reputation.
Petronix I.E.
Good morning. I'd like to upgrade from points to a Petronix I.E.
Please tell me, if possible, which unit I need for a '50 F1, 6 cyl, 6 volt positive ground with a FOMOCO distributor.
I'm hoping there's a fellow member that's completed this that'll have a concrete part number to share.
Thanks in advance for any help.
Old 08-24-2014, 10:09 AM
HBN's Avatar
HBN HBN is offline
HBN is starting off with a positive reputation.
I converted my six over to pertronix. I called and talked to one of their techs to make sure I got the right one. The guy at the local parts store didn't have a clue on which one to use, even though they were a distributor for Pertronix. Simple process, and I'm happy with the results.
Dave
Old 08-25-2014, 05:17 AM
Quote:
Dave
Thanks HBN. please tell me, might you still have the box it came in for a part number or remember the part number?
Also might you have an extra 6 volt wide belt generator pulley you could stand to part with?
Thanks either way in advance, Douglas
Old 08-25-2014, 05:31 AM
HBN's Avatar
HBN HBN is offline
After talking to the Pertronix tech, I ordered the 1266P6 from Mac's. I believe its the one for the D shaped distributor shaft. Sorry, but I don't have another pulley.
Dave
Old 08-25-2014, 06:08 AM
Thanks HBN Dave. Onward & upward!
Old 08-25-2014, 06:18 AM
Forgot to ask, did you also "upgrade" the coil as well? Thanks again.
Old 08-25-2014, 07:42 AM
Dave
Do I ever understand about the local parts store not having a clue. I'm doing a restore on a '56 Shasta trailer. 2 different time on the paint mixing's, well it's gone all wrong. The first time on a plain ole red, we got a pink. The second on a plain ole silver, we pretty much got a clear coat with just a hint of silver. Didn't even come close to covering the primer.
Old 08-26-2014, 12:42 PM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is online now
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
Calling Petronix is the best bet. My 1956 F100 truck has a 272 Y Block in it but the distributor is a later model (57 up) with both vacuum and centrifugal advances. There are two different sets for the different distributors.
About the coil YES change it out too. When I changed both the ignition (Ignitor III) and coil (Flamethrower III) I also removed the resistor (OKed in the accompanying literature) off the firewall.
Very pleased with the results!
going from points to electonic dist, need advise... fatheroftwo Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 16 03-11-2016 06:31 AM
1978 361 won't idle when warm - electrical problem? Pinzer Electrical Systems/Wiring 18 01-20-2016 12:13 AM
352 with MSD question bphirt1 1961 - 1966 F-100 & Larger F-Series Trucks 5 10-04-2015 11:02 AM
Petronix? Mitch1129 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 02-23-2015 11:50 AM
Petronix for a 62 F100 223 6 Cyl BeerKnurd 1961 - 1963 F100 Unibody 1 02-08-2015 05:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
