2002 F250 motor noises passenger side - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-23-2014, 11:16 PM
creature13 creature13 is offline
creature13 is starting off with a positive reputation.
2002 f250 5.4 250,000 miles... little history. its blown plugs both sides 3rd back on each. fuel pump shorted and fried pump relay, replaced entire board as they are soldered to it.. misc coil packs over the years. but...
a few weeks ago it started a chirping / squealing and misfiring on passenger side. it comes and goes but is steady under load.
back off the throttle and you can hear a click kinda whoop noise and everything is good....but push back on the throttle a little too much and its back. Ease away from a stop, get on a flat road everything ok... can go 70 or 80mph and no missing....no chirping. Hit a slight upgrade and it start start chirping and missing.
hot or cold. start the truck up and sometime noise...sometimes nothing. push on accelerator slowly and nothing. rev to 5 grand nothing. hit it quick and it will chirp. Sometimes it stay on ...sometime not
Seems to be just one cylinder is it a funked up coil pack or injector
Old 08-24-2014, 06:21 PM
speakerfritz's Avatar
speakerfritz speakerfritz is offline
speakerfritz is gaining momentum as a positive member of FTE.speakerfritz is gaining momentum as a positive member of FTE.
I have had 2 super dutys and don't ever recall reving them past 2500 rpms. Maybe if I reved my trucks passed 5000 rpms it might chirp also.
what conditions result in 5000 rpm operations?
Old 08-25-2014, 07:21 PM
3/4ton4X4's Avatar
3/4ton4X4 3/4ton4X4 is offline
3/4ton4X4 is starting off with a positive reputation.
I beat on my truck pretty hard and it sees 4500 every time its out haha. but its not a daily driver anymore and its mostly for offroad use. My 5.4 lasted till 300k driving like this and a failed oil pump finnaly took out a rod bearing. sorry to not help with the thread but im just sticking up for the 5.4 a little, they make most of their power above 3500 rpm. speakerfritz if you keep up the easy driving you will see 500k haha!
Old 08-25-2014, 07:26 PM
3/4ton4X4's Avatar
I guess i can help a little, Coils go out on me all the time because i get water and mud up in there and whenever i drop a coil my truck just simply runs bad. Lots of miss fires lots of bogging out under a load and some small back fires from fuel loading up in the cylinder and a smell of unburned fuel and a hot catalytic converter coming from the exhaust. The same symptoms can be found with a bad injector, but it can depend on what is wrong with the injector. If its leaking you will see similar problems to the bad coil like smelling unburned fuel and lots of little miss fires. If the injector has stopped working you will notice a loss of power and miss fires. Is the truck throwing any codes?
Help!! Plz newb here 6.0 chirping loud Mikelangevin 1999 to 2016 Super Duty 8 04-10-2016 12:09 PM
Chirping noise from Rear axle when accelerating Billy22 Ranger & B-Series 10 02-18-2012 04:27 PM
Chirping and grinding noise 2000 F250 FoundOffRoadDominate 1999 to 2016 Super Duty 12 01-24-2012 08:35 PM
Chirp/squeek in passenger side of dash EatBeef 1999 to 2016 Super Duty 12 03-05-2011 10:10 AM
Horn Chirp, Door Lock GIANTOAK555 2007 - 2014 Expedition & Navigator 0 12-30-2008 02:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
