fuel light
Old 08-23-2014, 10:07 PM
kburch100's Avatar
kburch100
kburch100 is offline
fuel light
I just bought 97 f250 and the fuel filter light was on so I replaced it but looked new truck made it maybe a mile and died. The fuel pump was replaced in January took the filter out a spun over the truck fuel was pumping but not a lot. Filled the filter bowel up with tranny fluid started but runs really bad filter light does not go off
Old 08-24-2014, 08:31 AM
farmert's Avatar
farmert
farmert is online now
The fuel filter light senses a restriction in the fuel flow, so you may have some debries in the tank, and the fuel pickup "showerhead" may be clogged. does the light stay on if you switch the tank to the other one? By the way, welcome to the Ford Trucks forums!
Old 08-24-2014, 09:46 AM
kburch100's Avatar
kburch100
Yes sir the light never goes off and the truck runs really bad if I can get it to start but will a bad turbo keep it from starting?
Old 08-24-2014, 12:35 PM
farmert's Avatar
farmert
A bad turbo will not keep it from starting. I think you have a blockage in the fuel lines. I would start by inspecting the lines, and blowing air threw the fuel line from the engine bay back to the fuel tank selector valve.
Old 08-24-2014, 12:41 PM
kburch100's Avatar
kburch100
I spun the truck over and the filter bowel is filling up but still won't run good
Old 08-24-2014, 04:37 PM
Robbieo11's Avatar
Robbieo11
Robbieo11 is offline
Start checking lines. Idk if the is a filter on frame rail or not. But pumping and pressurizing fuel are 2 different things so look for the restriction ie volume
Lucas LaFave
11-26-2019 10:34 AM
filadog23c
11-06-2019 10:45 AM
rjrandy96
20
11-25-2013 06:53 PM
thebig350
12-28-2010 08:22 PM
dkrahn
05-26-2007 09:04 PM
Quick Reply: fuel light
