53 f100 crown Vic front end - Ford Truck Enthusiasts Forums
Old 08-23-2014, 10:47 PM
DasHaas DasHaas is offline
DasHaas is starting off with a positive reputation.
I'm at the point on my build where I need to address the frame and suspension. Not sure what to do for the rear yet but I'm looking to put a crown vic front end in my truck. Any suggestions on what year to look for or stay away from? I have also noticed That the crown Vic front ends have engine mounts, does anyone know if these mounts will match up with a 302 block?
Old 08-24-2014, 02:01 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1979/2002 LTD/Crown Victoria/Grand Marquis have worm and roller steering.
2003/2011's have rack and pinion steering.
Crown Victoria name replaced LTD in 1982.
Old 08-24-2014, 08:51 AM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is offline
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
2003 and up have an aluminum crossmember. Name:  image.jpg
No cutting of the frame involved, but there is a little fabrication and a bit of welding.
Old 08-25-2014, 04:23 PM
Thanks guys, this definitely seems like the way to go, but do you know if a 302 will fit on those motor mounts?
Old 08-25-2014, 05:27 PM
I'm sure someone has done it but the 302 is narrower than the 4.6. Sooo looks like you may need to make some sort of motor mount adapter.
https://www.fordracingparts.com/down...Dimensions.pdf
Old 08-25-2014, 06:44 PM
Scot's Avatar
Scot Scot is offline
Scot is starting off with a positive reputation.
Yes I am running a 302 on the stock square mounts. I used a donut mount on top and a 1/4" triangular mount on top bolted to the stock 302 mounting holes.
Old 08-25-2014, 07:58 PM
clintonvillian clintonvillian is offline
clintonvillian has a good reputation on FTE.clintonvillian has a good reputation on FTE.clintonvillian has a good reputation on FTE.
A little time and you can make a really attractive suspension:
Old 08-25-2014, 08:54 PM
dynamic's Avatar
dynamic dynamic is offline
dynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to behold
Quote:
Originally Posted by bjmayberry2 View Post
2003 and up have an aluminum crossmember. Attachment 104532
Hey those are some nice photos u have there.
Old 08-25-2014, 09:17 PM
Quote:
Humm wonder where they're from.
Old 08-25-2014, 10:40 PM
Thanks for the info @scot! Do you have any reference pics or links to the adapters you used?
Old 08-25-2014, 10:41 PM
@clintonvillan.. That looks absolutely beautiful! Very clean work!!
Old 08-26-2014, 07:09 AM
dynamic's Avatar
Here are some shots of the welding required....
Old 08-31-2014, 04:33 PM
Scot's Avatar
I think these mounts came from an early 90's 5. 0 Cougar but don't remember for sure. Yes, my shop sort of looks like a dumpster...
<a href="http://s270.photobucket.com/user/nozzleman201/media/z2photo.jpg.html" target="_blank"><img src="http://i270.photobucket.com/albums/jj105/nozzleman201/z2photo.jpg" border="0" alt=" photo z2photo.jpg"/></a>
<a href="http://s270.photobucket.com/user/nozzleman201/media/z1photo.jpg.html" target="_blank"><img src="http://i270.photobucket.com/albums/jj105/nozzleman201/z1photo.jpg" border="0" alt=" photo z1photo.jpg"/></a>
Old 08-31-2014, 06:00 PM
Did any of you fellas happen to measure the center distance between the two studs on the lower control arms?
Anyone have pictures of crown vic seats? dentsides 1973 - 1979 F-100 & Larger F-Series Trucks 0 05-20-2016 03:09 AM
crown vic parts. 460harris 1973 - 1979 F-100 & Larger F-Series Trucks 5 12-05-2015 11:01 PM
Crown Vic front swap Andy1966 1961 - 1966 F-100 & Larger F-Series Trucks 4 09-12-2014 12:57 AM
F100 crown vic front end and steering column JRD2849 1967 - 1972 F-100 & Larger F-Series Trucks 1 08-20-2013 12:46 AM
crown vic swap reservations lefty rodan 1961 - 1966 F-100 & Larger F-Series Trucks 41 07-18-2013 01:22 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
