Fog light installation ideas needed - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-23-2014, 08:13 PM
Vijay's Avatar
Vijay Vijay is offline
Vijay is gaining momentum as a positive member of FTE.
I need to install two LED fog lights on my Ford f 350 Dually. My truck did not come with fog lights from the factory(so there is no wires to tap into). The std wiring kits that are available online suggests to directly tap into battery. I’m not too sure of that. Any other ideas? Perhaps, splice another live source? I really want the lights to be on all the time (when the headlights are ON off course). My truck is now my daily driver (at least until I find another replacement for my Jeep…another Jeep? Tacoma?).
Old 08-23-2014, 11:42 PM
Sous's Avatar
Sous Sous is online now
Sous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud of
You could use a relay and tap into the headlights that way. Then you would have the fog lights on when the headlights come on and not draw power from the headlights wire. Although, switching from low to high beam may cause an issue depending on how they are wired.
08-10 XL Oem Fog Light Install Issue F.X.5 1999 to 2016 Super Duty 3 11-30-2015 05:06 PM
Fog Lights?? Supercab 6.0L Power Stroke Diesel 2 08-14-2014 09:04 PM
2005 F250 fog lights bgilber5 Large Truck 2 05-22-2014 02:13 AM
Need help wiring KC lights Rwolfe1988 Electrical Systems/Wiring 6 02-02-2013 09:54 AM
Fog Lights for a 1999 150 FKNVA Electrical Systems/Wiring 5 11-21-2002 08:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
