2003 Stock F350 "Offroad"...Tire/Rim questions - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-23-2014, 07:50 PM
doncuomo doncuomo is offline
doncuomo is starting off with a positive reputation.
Hi all,
I am very new to the forum and to a lesser degree, my 2003 F350 (4x4 offroad). I have been using this truck for various personal jobs around the property and plowing.
I have been running it with all terrain stock size tires (265 75 16) and chains in the winter but want to switch to a set of BLIZZAK W965E (235 75 16) tires for winter. I have a 1200' long driveway and it is all on a grade (4-17%).
That means a new set of "summer" rims which I have been very excited about...almost as excited as my 14 year old son who is beside himself with the idea of bigger wheels. So....
I picked up, off of Craigs List, a set of American Racing Baha 16" x 10" rims (-25 offset....4.52" back spacing). They came mounted with a set of ruined Firestone Destination AT 315 x 75 x 16 tires
I mounted these (front only) to see if they would fit and they did not...but...only rubbed at the back of the wheel well on the plastic liner at full turn. Remember, this is the "Offroad" and came with a small factory lift. Does anyone know the actual inches of lift this truck has?
I wanted some collective wisdom on what to do from here. My local Mavis says a 305 70 16 Cooper AT should do the trick. I am hoping some of you have experience with this arrangement on a stock "offroad" 2003 f350?
I want to avoid any additional lifting...but would consider a fender shim or trim if necessary.... although the 315's did not hit the front fender; very close but not touching.
I would consider selling the AR rims if there are two few options, or other issues I'm not aware of, and going with a 16" x 8" rim and something like a 285 75 16.
Any advice on any of the above would be very much appreciated.
Don
Old 08-24-2014, 07:24 PM
speakerfritz's Avatar
speakerfritz speakerfritz is offline
speakerfritz is gaining momentum as a positive member of FTE.speakerfritz is gaining momentum as a positive member of FTE.
wheels spacers....and for those who are going to jump in and say they are a bad idea, my 2008 f-350 has front wheel spacers stock from the factory ,.....so don't let the ney sayers rain on your parade...its an inexpensive fix.
315/75/R16 with no lift. TARHEEL57 1999 to 2016 Super Duty 6 01-11-2015 12:42 AM
Time for tires. Need your suggestions!! clintusaf 1999 - 2003 7.3L Power Stroke Diesel 32 02-02-2013 08:07 PM
How to measure backspacing on rims Northern Caveman 1999 to 2016 Super Duty 2 07-21-2011 10:34 PM
Rim Backspacing mobriensnow 1999 to 2016 Super Duty 4 01-11-2009 05:33 PM
How to fit 315/75/16 tires on a 95 F250 Lambo333 1987 - 1996 F150 & Larger F-Series Trucks 5 07-22-2007 03:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
