Turn signals not working
Old 08-23-2014, 06:35 PM
Ronnie Gilliam's Avatar
Ronnie Gilliam
Ronnie Gilliam is offline
I have a 1997 7.3 450 and my turn signals recently stopped working. I changed the turn signal switch and that didn't fix it. Checked
Fuses, the wipers work, brake lights work, hazard lights work but just not the turn signals!
Old 08-23-2014, 07:59 PM
farmert's Avatar
farmert
farmert is offline
Check the flasher relay in the in cab fuse panel. It is the round thing about the size of a quarter.
Old 08-25-2014, 12:44 PM
Ronnie Gilliam
Wouldn't the flashers not work if that was bad ?
Old 08-25-2014, 01:28 PM
Hussler's Avatar
Hussler
Hussler is offline
No, flasher relay is behind the fuse panel.
Old 08-25-2014, 02:12 PM
madpogue's Avatar
madpogue
madpogue is offline
To clarify, the turn signal flasher is on the side of the fuse panel you can see. The hazard flasher is on the "blind" side of the panel. Nice situation for testing if you don't have a spare. You simply switch them with one another. If the problem "moves" to the hazards, then that indicates a bad flasher. If not, the problem is elsewhere (switch, wiring, etc).
(And neither one is a relay.....)
Tomahak
01-26-2013 12:47 PM
bcaughhorn
1997 - 2003 F150
01-24-2013 07:21 PM
STRANGER RANGER2
10-20-2008 10:22 AM
dinikin
21
11-04-2007 01:34 PM
breahnight
1978 - 1996 Big Bronco
03-12-2004 09:29 AM
Quick Reply: Turn signals not working
