Tried it all!!! - Page 2 - Ford Truck Enthusiasts Forums
Tried it all!!!
Old 08-24-2014, 06:35 AM
Alleycat3677 Alleycat3677 is offline
Alleycat3677 is starting off with a positive reputation.
Funny you should say that. I actually replace the accelerator pump and rubber valve because I thought that was the issue.
Old 08-24-2014, 06:52 AM
trozei's Avatar
trozei trozei is offline
trozei has a great reputation on FTE.trozei has a great reputation on FTE.trozei has a great reputation on FTE.trozei has a great reputation on FTE.trozei has a great reputation on FTE.
Pull the breather off and look down the carburetor. Move the throttle bracket. Right away you should see fuel squirt into the carburetor. If you don't, there's your problem.
Old 08-24-2014, 07:06 AM
Yup. Two good squirts of fuel. Like I said. Kinda at a loss with this one.
Old 08-24-2014, 09:51 AM
Rasputin53's Avatar
Rasputin53 Rasputin53 is offline
Rasputin53 is gaining momentum as a positive member of FTE.Rasputin53 is gaining momentum as a positive member of FTE.
Sounds like you do not have enough vacuum. There can be several reasons for this including a lack of flatness in the bottom of the carb or in either side of the spacer. First measure your vacuum at idle.
Old 08-24-2014, 10:38 AM
Again. Funny you say that. Just got done putting the vacuum guadge on it. At idle it's reading 10. When I give it gas it jumps to 15. If I'm not mistaken it should read zero until I give her gas. Timing was set with the vacuum disconnected and plugged. What next?????
Old 08-24-2014, 10:53 AM
351Cleveland C4's Avatar
351Cleveland C4 351Cleveland C4 is offline
351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.
That's low. That's very low. Idle should be at least 15. More like 20.
What vacuum did you hook up to? Manifold or ported?
Old 08-24-2014, 10:55 AM
It's hooked into a port on the carb under the accelerator pump.
Old 08-24-2014, 10:56 AM
That brings up another question, is the distributor hooked up to the right port? Should be the one on the passenger side going sideways.
Old 08-24-2014, 10:58 AM
Your right. That's where it is.
Old 08-24-2014, 11:01 AM
That's the only vacuum line besides the choke tube for heat.
Old 08-24-2014, 11:13 AM
Alex from GA Alex from GA is offline
Alex from GA is starting off with a positive reputation.
Vacuum gauge is connected to manifold vacuum. If you have power brakes there should be a tree behind the carburetor coming straight from the intake manifold. Have you taken a compression check? That's the first thing to do in a tune up. Like 351 said, the vacuum is very low, it needs to be 15 or more at idle with the stock cam.
Old 08-24-2014, 12:16 PM
Set timing to 12*btc, idle speed to about 650-700, then use your vacuum gauge to tune the mixture. Should be somewhere around 1-1/2 to 2 turns rich. Go for the highest reading.
If that doesn't do it, you've got other problems. A vacuum leak somewhere, or just a worn out motor.
  #28
Old 08-24-2014, 02:24 PM
I think I may just have a wore out engine. I'll drive her til she quits then get a crate 390. Thanks for all the help!!!
  #29
Old 08-24-2014, 02:34 PM
trozei's Avatar
Quote:
No, don't give up. Check your compression and double-check your vacuum. There is no use for you to not want to know what the problem is.
  #30
Old 08-24-2014, 02:36 PM
Number 8 cylender is reading 65 psi. I don't have the skills to do a rebuild and the time with a 3yr old. So I'll save my pennies and get a crate motor or find a low milage donor. I can easily do an engine swap!!!!! Two days work.
How do you check the lifters and rollers? RoryTheFerret Modular V8 (4.6L, 5.4L) 1 04-06-2016 05:54 PM
78 f150, just installed elec fuel pump, runs great! but has gas smell in engine compartment? F350dog 1973 - 1979 F-100 & Larger F-Series Trucks 1 09-23-2015 07:46 AM
HELP! My 2004 f350 6.0 cranks but wont start Erilazaro 6.0L Power Stroke Diesel 23 06-22-2015 11:52 AM
1995 died while driving and no restart 1993_f350_2013 1987 - 1996 F150 & Larger F-Series Trucks 62 01-02-2015 11:24 PM
1980 Ford F250 issues Chevellenut1973 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 06-23-2014 06:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
