Engine Stall declaration - Ford Truck Enthusiasts Forums
Old 08-23-2014, 05:31 PM
Krinderhagen Krinderhagen is offline
Krinderhagen is starting off with a positive reputation.
1988 F250 Lariat Diesel
Engine stalls after releasing throttle pedal i was considering the temperature though after running for 40 minutes at idle in park not would not reach 192 degrees, there was word that pistons burn so i think a cylinder test would be appropriate
Anyone with heads up on the situation
The gauge on the dash is almost half using a Cen tech infrared thermometer
The temperature at the thermostat housing and neck read between 178 and 183
08/22/2014 F250 Lariat thermo temp
1988 F250 Temp gauge reading
when accelerating at 2000 RPM for few the releasing the throttle the engine quits same scenario when driving and preparing to stop the engine will quit
Video
after letting it idle for 15 minutes it still has not reached temperature above 190 so have ot been able to check if thermostat opens
A new thermostat calls for Part Number: 4399
Weight: 0.2 lbs
Warranty: 1 YR
Application: OE recommended temperature
Notes: 195 degreesSeal included
Gaskets Included: Yes
Material: Stainless Steel, Copper
Package Contents: Thermostat, Gasket
Thermostat Opening Temperature (F): 195
Old 08-23-2014, 05:39 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Did you replace the thermostat?
You listed its part number its ratings and specs but didn't read where you stated that you had put a new one in.
Old 08-23-2014, 10:44 PM
thank you
no i haven't replaced the thermostat i am doubting is the problem as it does not reach temp though will soon as i get a chance
Old 08-24-2014, 07:03 AM
dixie460's Avatar
dixie460 dixie460 is offline
dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.
A busted thermostat can cause your truck not to warm up. When I bought my current truck, it wouldn't warm up for crap. Took the t-stat housing off and the old thermostat came out in three pieces. Lol.
Old 08-24-2014, 09:23 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
engine stalling after releasing throttle has nothing to do with the engine temp. it is a sign of injector pump problems.
first thing to do is fire the engine up and get it warm.
then shut it off and remove the fuel filter. drain it, and fill with ATF.
put it back on and start the engine. let it idle for 30-45 seconds and shut off.
then let it sit for at least 12 hours, 24 hours is better.
the ATF will clean the crud off the inside of the injector pump.
if this does not fix the stalling problem, you will probably need a new injector pump.
TV CABLE "...Kick..Down.." cable dilemma Montync Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 02-17-2017 08:41 AM
245's on my 450 and tonno cover bronc71 2017 Super Duty 76 02-16-2017 02:18 PM
Transmission identification moonley 1957 - 1960 F100 & Larger F-Series Trucks 2 02-06-2017 08:09 PM
What is this part called? Old Gal 1999 to 2016 Super Duty 7 01-07-2015 12:26 AM
sludge on fuel filter 96_F250_Deezal 6.0L Power Stroke Diesel 19 12-22-2014 10:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
