VSS issue - Ford Truck Enthusiasts Forums
VSS issue
Old 08-23-2014, 06:26 PM
naturescape naturescape is offline
naturescape is starting off with a positive reputation.
VSS issue
I have a 97 f250 with 355,000. I had transmission issues last year and put a used transmission in . It shifted a little hard but it is a e40d. Sometimes while driving it would basically act like you were in nuetral. Also would shift funny. The OD light was flashing so I put the computer on it . Bad cam sensor and P500. I went to ford and got a vss. Put in and the truck worked like a charm . Also got my cruise control back. It starting acting up again. Then would be fine . I bought another sensor and worked. It acts up every once in a while . When I shut the truck while driving and turn back on it picks right up with the speed . When the od is flashing and I do the same thing the trucks acts like it is in neutral.. Not sure if it matters but my alternator gauge is all over the place . I did test the batteries and the alt and they are at a steady 13.5 or so Thx
Old 08-23-2014, 06:31 PM
ABS light is on too
Old 08-23-2014, 07:15 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Check out the wiring that goes to the VSS. That harness tends to rub on the shocks and suspension back there and a chaffed wire or two would make it look to the PCM like the VSS isnt working.
Also pull the VSS and make sure there isn't a bunch of little metal shavings stuck to then face of the VSS. If there is metal in the oil from worn gears or bearings and it sticks to the magnetic sensor, it will affect the readings it gets.
Wherebdid you get the VSS? Is it a Motorcraft part?
overdrive light flashing porkchop0119 1999 - 2003 7.3L Power Stroke Diesel 8 06-08-2016 07:12 PM
PSOM Issues? E55 Bulldog 1994.5 - 1997 7.3L Power Stroke Diesel 10 03-24-2016 02:30 PM
Code 452 tony. b 1987 - 1996 F150 & Larger F-Series Trucks 8 07-09-2014 03:21 PM
OD off light flashes with tranny issues sandaholics Modular V10 (6.8l) 3 08-15-2011 12:54 PM
95 F150 hard shifting and erratic speedo BRay09 1987 - 1996 F150 & Larger F-Series Trucks 23 07-06-2011 10:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
