Oil Viscosity?? - Ford Truck Enthusiasts Forums
Oil Viscosity??
Old 08-23-2014, 03:55 PM
tom18287 tom18287 is offline
tom18287 is starting off with a positive reputation.
Oil Viscosity??
Hey guys
Gonna change the oil in my f350 dump truck, should i use the 5w40 recommended for heavy duty use? tow a bobcat a few times a month as well as a dump trailer, and obviously use it as a dump truck often, but i still think the truck has an easy life as far as dump trucks go. i don't work it too hard but if i should use the heavy oil then i will.
thanks
Old 08-23-2014, 04:24 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
That is what I run and based upon what you do with it I think so as well.
Old 08-24-2014, 08:02 AM
Karl4Cat's Avatar
Karl4Cat Karl4Cat is offline
Karl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputation
Tom, since 5w40 syn is the same price as 10w30, even if you're not using your truck hard, why not? Rotella T6 is $22 a gallon at Walmart.
Old 08-24-2014, 08:40 AM
is it ok that i'm in the northeast where it gets cold? sorry, i really don't know much about this stuff
Old 08-24-2014, 08:44 AM
senix's Avatar
Read the owners manual. It will indicate the viscosity of the oil you should use according to the temps.
I think you will be fine myself.
Also did your truck come with the engine block heater?
Karl4Cat's Avatar
Absolutely! With the cold weight being 5 instead of 10 it actually flows better at low temps and protects better at high temps being 40 instead of 30...
Old 08-24-2014, 08:48 AM
yeah it has the engine block heater, as if it needs it the glow plugs are amazingly fast. the only reason i use it is for instant heat
Old 08-24-2014, 09:03 AM
Tom's Avatar
Tom Tom is offline
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Either oil will do fine for your use. Most dealers don't have the owner fill out a questionnaire before they do an oil change, they just put the factory recommended 10w30 in.
I'd use 10w30 if I were you and switch to 5w40 for the winter.
Old 08-24-2014, 09:09 AM
Karl4Cat's Avatar
Quote:
Actually, 5/40 would be the better weight year round.
Old 08-24-2014, 09:25 AM
Tom's Avatar
Tom Tom is offline
Quote:
But a little more expensive and for little gain during the summer time. The big issue is cold starting during the winter, and that's where having a thinner synthetic oil would really pay off. Lots of talk about thicker oils for high ambient temperatures, but I agave yet to see a bad UOA with factory specified oil.
Old 08-24-2014, 09:27 AM
Karl4Cat's Avatar
10/30 is less than 22 a gallon? I guess I never priced it...
ruschejj's Avatar
ruschejj ruschejj is offline
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
The beauty of that 5w/40 synthetic. It is especially valuable to all you northerners in my opinion. It's like super slick water at 70 and up. Your cold weather performance is only a big deal when you first start it, right?
I think the T6 would be a great choice and it's cheaper than the Motorcraft.
Unless there's been a change, I remember the Motorcraft being almost $10 more/gal than the shell.
Old 08-24-2014, 09:30 AM
Karl4Cat's Avatar
That's what I was thinking but couldn't argue price with mod Tom as I've never considered 10/30 so never priced it...
Old 08-24-2014, 09:34 AM
ruschejj's Avatar
Just wait for it, tom won't let it go for long, lol....
Old 08-24-2014, 09:49 AM
Tom's Avatar
Tom Tom is offline
Yeah, I haven't looked in a year or so but I believe it can be had for around $15-16/gal for T5 synthetic blend. That's about $15 less for an oil change.
Who...me?
Truck hoist oil? ireding 1957 - 1960 F100 & Larger F-Series Trucks 3 08-24-2014 01:42 AM
Anyone experienced with PTO dumps? Gettysburg150 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 04-11-2013 10:21 AM
1967 F350 Dump bed piney1 1967 - 1972 F-100 & Larger F-Series Trucks 5 10-07-2010 05:48 PM
1991 F700 Dump truck Catch86 Large Truck 0 09-26-2009 03:07 PM
1953 Ford F700, Big Job Dump Truck bigjob 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 05-02-2004 02:39 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
