Mishimoto 200° vs. Ford 192° thermostat
Old 08-29-2014, 05:03 AM
2006lariat's Avatar
2006lariat
2006lariat is offline
I wish I wasn't this way. I would much rather not want to sleep when it is sunny out!
Any how, how is this 200* thermostat working out?
  #77
Old 08-29-2014, 05:08 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is online now
It looks good on the workbench lol, I hope to get it and the radiator installed this weekend.
  #78
Old 08-29-2014, 06:43 AM
Number21's Avatar
Number21
Number21 is offline
Originally Posted by Rusty Axlerod
More early risers! Or never went to beders?
You can sleep when you're dead.
  #79
Old 08-29-2014, 09:41 AM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
Only time I can work on the cars is overnight, it's too damn hot during the day even with a swamp cooler running. Planning on doing shocks/struts and brakes on a Jeep this weekend, God willing between 10pm and 6am.
  #80
Old 08-29-2014, 10:27 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
Thanks everyone.
They FINALY got the filter fixed.
I now get my Ford-Trucks.com stuff right.
How I hate early Dr appointments.
Sean
  #81
Old 08-29-2014, 01:51 PM
Money-Pit's Avatar
Money-Pit
Money-Pit is offline
Originally Posted by Per4mance
I think doing this may change all parameters of the pids.....
I'm curious here....what are you thinking will change?
Does anyone think I should disconnect the batteries so everything is re-learnt? (yes, I'm from the South)
  #82
Old 08-29-2014, 02:36 PM
samsdad02's Avatar
samsdad02
samsdad02 is offline
too anyone who installed one,was the silver shaft longer than the stock? Mine is about 1/8" longer and the stat flange won't seat against the housing. been waiting a long time for Mishimoto to get back to me if this is normal or not.
can't see how it would be, as coolant would flow past the stat regardless of temp.
  #83
Old 08-29-2014, 02:39 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
It won't effect anything, just better MPG
Josh
  #84
Old 08-29-2014, 04:07 PM
samsdad02's Avatar
samsdad02
heard back from Mishimoto. My stat is not correct. they are going to send me a new one. guess I get to do it again. sigh...
  #85
Old 08-29-2014, 04:16 PM
Rusty Axlerod
Well dang! Was it P/N MMTS-F2D-03H? And which part was too long? Was it this
I've only seen a post from one other person who installed the 200° stat and they commented that it was tough to compress the spring to get it in the housing. Kinda was a red flag for me at the time and I intended to look closely...
  #86
Old 08-29-2014, 05:41 PM
Money-Pit's Avatar
Money-Pit
That sucks. Was that XDP's mistake, or was the wrong t stat in the right box? Mine was longer overall as seen in the pictures, but it doesn't effect the installation/sealing. Although the beefy spring made it fun to install it in the housing.
  #87
Old 08-29-2014, 05:43 PM
Money-Pit's Avatar
Money-Pit
Do some thumb exercises before installing....you'll be fine.
  #88
Old 08-29-2014, 08:32 PM
samsdad02's Avatar
samsdad02
yup, too long by an 1/8". I'll check the pn# in the morning. I did manage to get it mounted, but the sheet metal flange had a gap between it and the housing.
I drilled the housing a little bit and it was better.
  #89
Old 08-30-2014, 12:58 AM
ammosdad's Avatar
ammosdad
ammosdad is offline
To Long
I tried to install the Mishimoto thermostat, and had the same problem. It will not fit in the Ford T-Stat Housing, the dimensions and spacing do not match the OEM.
I'll try to post pics later.
  #90
Old 08-30-2014, 05:10 AM
samsdad02's Avatar
samsdad02
pn# mmts-f2d-03h.
The aftermarket housing wasn't even close. I had 2 old housings (I'm a pack rat) Ford pn# on them. One ended in a 1 the other a 2. went to ford and bought a new one. I think it ended in 1, I drilled the old one's shaft hole a little till it fit.
I think I'll put the ford stat in till I get the new mishimoto one. My ect hit 206* then drop back to 202*. My cooling fan runs enough that I can hear it doing 50.
Quick Reply: Mishimoto 200° vs. Ford 192° thermostat
