1996 f-250 cuts out
Old 08-23-2014, 08:59 AM
tjb120's Avatar
tjb120
tjb120 is offline
1996 f-250 cuts out
I have a 96 F250 with 7.3 powerstroke that will just up and die like you turned the key off. After cycling the key it will restart and run but will intermittently cutout four or five times and then run fine. Seems to do this when I hit the brakes. If I have my trailer brake regulator hooked up it will do it immediately if I hit the brakes every time. I have checked all of my grounds and harnesses and can find nothing wrong. Would a week camshaft position sensor be causing this? Thanks for any help guys.
Old 08-23-2014, 10:09 AM
fordpride's Avatar
fordpride
fordpride is offline
Sounds like a bad cam sensor (cps)
PhilWiles
07-19-2010 06:20 PM
matt12
01-03-2010 05:36 PM
bdjupiter
18
08-17-2007 01:35 PM
Hi-psi
08-26-2005 11:55 AM
Willie19992000
07-28-2005 05:30 AM
Quick Reply: 1996 f-250 cuts out
