Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Old 08-23-2014, 12:07 AM
chaser1602 chaser1602 is offline
chaser1602 is starting off with a positive reputation.
Styleside tail lights
I need the part that the bulb goes into that holds the lense. Not much luck finding new. Anyone got a lead???
Old 08-23-2014, 10:51 AM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 is a splendid one to beholdtinman52 is a splendid one to beholdtinman52 is a splendid one to beholdtinman52 is a splendid one to beholdtinman52 is a splendid one to beholdtinman52 is a splendid one to beholdtinman52 is a splendid one to beholdtinman52 is a splendid one to behold
Which style.....the round one or the long narrow one?
__________________
Scott
'99 F250 SD 4x4, '62 F100 4x4, '52 F-1
My COE build thread;
http://www.ford-trucks.com/forums/11...uck-build.html
"you can call a pig a duck, but that won't make it quack!"
Old 08-23-2014, 12:08 PM
daveengelson daveengelson is online now
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
Yesterday placed order for flareside lens thru Obsolete/Classic Auto parts and noticed they carry the taillight assemblies for both. Believe they use to go by Obsolete Ford parts until FoMoCo made a stink; purchased numerous items from Obsolete Ford parts and always please w/ the quality, located in Oklahoma. Page 136 in their pdf online catalog. I just type in the page # in the page box and hit enter.
http://www.classicautopartsonlinecat...kCode=fpu13flx
While cyber shopping for the lens came across Carolina Classic's and noticed they carry the both type lens but did not browse their cat. for the assembly. Located in Durham, NC. Posting a link; read a thread couple days back where apparently there are couple Ford part supplier's that go by same name??? If not in cat. might want to give them a call??
Carolina Classics, Obsolete Ford Truck Parts, truck part, ford truck part, truck body parts, classic truck part, pickup truck part, old truck part, classic ford truck part, antique truck part, old ford truck part, auto truck part, ford truck restorat
__________________
'problem with engaging in useless activity is never knowing when your done'
Dave
65F100, 302ci, T18, swb, flareside,front disc. PS, Duraspark Ign.(Daily Driver)
65F100, 390ci, 3sp.OD, lwb, styleside, front disc., Duraspark Ign.
Old 08-23-2014, 01:02 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Question Styleside tail lights
Please, when asking questions, list all the pertinent details: Year, type of Styleside bed, 2WD or 4WD.
1961/66 F100/350 Stylesides with 1957/60 "wrong" beds. The lenses are reproduced, the bodies are not reproduced, only available used.
C2TZ-13434-A .. Right & Left Tail Lamp Bodies / Obsolete ~ No Ford Dealer or obsolete parts vendor has any.
1964/66 F100/250 2WD & 1966 F100 4WD Styleside lamps are the same, also the same as 1966 Bronco. These parts are right and left specific.
The lenses and gaskets are reproduced, the metal bodies are not reproduced, are only available NOS or used.
C4TZ-13434-B .. Right Tail Lamp Body-with socket & wiring / Obsolete
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
MCDONALD OBSOLETE PARTS CO. in Rockport IN has 1 = 812-359-4965.
MILLER OBSOLETE PARTS in Binghamton NY has 2 = 607-722-5371.
OBSOLETE RELIABLE PARTS in Nashville GA has 2 = 229-686-5101.
C4TZ-13435-B .. Left Tail Lamp Body w/socket & wiring / Obsolete
OBSOLETE RELIABLE PARTS has 1.
__________________
Bill / Retired Ford Parts Manager / SoCal Chapter Member / Part number research: 1928/2001 trucks & 1928/89 passenger cars.
2013 Escape FWD 2.0L Eco-Boost
Old 08-23-2014, 01:34 PM
I need the long narrow ones. The only ones I found were for a bronco that has reverse lights in them. Bronco style is fine by me if ya'll think it will come out right?
65 2wd I didn't know there was a different style of style side except for the older refridgerator trucks
Old 08-23-2014, 01:38 PM
Quote:
Backup lamps introduced in 1967.
Same right & left tail lamps: 1967/72 F100/350 Stylesides - 1967/74 Econoline Vans - 1967/77 Bronco's.
These lamps will work on 1964/66 F100/250 2WD's and 1966 F100 4WD Stylesides & 1966 Bronco, but...
These trucks and Bronco tail lamp wiring harnesses have no provision for backup lamps.
__________________
Old 08-23-2014, 02:05 PM
I called obsolete, Closed but I left a message. Probably be Monday. I am gonna buy the original B4 I go with bronco types. I Got a grip on all the reverse light have and have nots. I was wondering if I used the bronco type would it look right with the bulbs lit up or would some no it all be able to walk by and say "Hey those tail lights don't look right!"
Thanks for the help. I know I've been typing and surfing sights at the same time you have been posting and looking things up for me
Old 08-23-2014, 02:24 PM
The socket with pigtailed wiring is located in the lower section of the bodies with backup lamps. The backup lenses are incorporated into the tail light lenses.
These right & left specific parts bolt on without any mods to 1964/66 F100/250 2WD & 1966 F100 4WD Stylesides and 1966 Bronco's.
Parts Catalog pic: No back up lamp (lower) / With backup lamp (upper).
__________________
Old 08-23-2014, 03:37 PM
69supercj 69supercj is offline
69supercj is starting off with a positive reputation.
I've got a set of used original taillight bodies from a '66. Nice condition. I'd take 40.00 for the pair plus shipping.
Old 08-23-2014, 04:31 PM
Sorry, not paying attn: yet again, did not realize cover Bronco??
__________________
Dave
Old 08-23-2014, 04:52 PM
1966/72 & 1973/79 Bronco parts listed in the 1965/72 & 1973/79 Ford Passenger Car Parts Catalogs.
Left (upper): Bronco tail lamp pic same as in post #8 / Right (upper): 1973/77 Bronco, same as 1967/72.
__________________
Old 08-23-2014, 08:53 PM
resonateur's Avatar
resonateur resonateur is offline
resonateur is starting off with a positive reputation.
You might take advantage of the opportunity to obtain used original parts from members of the forum, such as 69supercj has offered. It might save you an extensive search. I have a pair as well if anyone is in need. So far, my experience on the buying and selling end of transactions through fte has been very favorable.
Old 08-23-2014, 08:56 PM
Quote:
Email me some pics chaser1602@hotmail.com or post them here
Old 08-24-2014, 08:54 AM
I emailed you some pics. They're in excellant condition and still have the factory zinc coating on them and the wiring is great as well. Look almost new.
Similar Threads
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 01:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 02:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 10:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 11:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
