Clutch pedal pushes brake pedal
1987 F-150, new to me. Depressing clutch pedal slightly depresses brake pedal, enough to slightly engage brakes. I can pull brake pedal up with my toes, but it'll happen the next time I push down on the clutch. More pronounced when engine is running. I've tried spraying with lube but no luck so far. Please let me have your thoughts....thanks in advance.
Received 3,099 Likes
on
on
Great write up with pictures of how to replace.
https://www.ford-trucks.com/forums/9...pic-heavy.html
Good info here too:
92 F150 4X4 won't start w/ clutch in and hard to shift - Ford F150 Forum
P/N for things you might want to replace while you're there:
<style type="text/css"><!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}--></style><table dir="ltr" style="table-layout:fixed;font-size:13px;font-family:arial,sans,sans-serif;border-collapse:collapse;border:1px solid #ccc" border="1" cellpadding="0" cellspacing="0"><colgroup><col width="207"><col width="105"></colgroup><tbody><tr style="height:17px;"><td style="padding:0px 3px 0px 3px;vertical-align:bottom;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">Clutch Rod Bushing</td><td style="padding:0px 3px 0px 3px;vertical-align:bottom;font-weight:bold;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">E69Z-7526-A</td></tr><tr style="height:17px;"><td style="padding:0px 3px 0px 3px;vertical-align:bottom;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">Clutch & Brake Pedal Bushing Kit</td><td style="padding:0px 3px 0px 3px;vertical-align:bottom;font-weight:bold;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">F3TZ-2C342-A</td></tr></tbody></table><style type="text/css"><!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}--></style><table dir="ltr" style="table-layout:fixed;font-size:13px;font-family:arial,sans,sans-serif;border-collapse:collapse;border:1px solid #ccc" border="1" cellpadding="0" cellspacing="0"><colgroup><col width="207"><col width="105"></colgroup><tbody><tr style="height:17px;"><td style="padding:0px 3px 0px 3px;vertical-align:bottom;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">Brake Rod Bushing</td><td style="padding:0px 3px 0px 3px;vertical-align:bottom;font-weight:bold;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">C9AZ-2474-A</td></tr><tr style="height:17px;"><td style="padding:0px 3px 0px 3px;vertical-align:bottom;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">Brake Rod Spacer (2 required)</td><td style="padding:0px 3px 0px 3px;vertical-align:bottom;font-weight:bold;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">C5DZ-2B129-B</td></tr></tbody></table>
This part is metal, I can't imagine it would wear unless you left the bushings in bad shape for years:
<style type="text/css"><!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}--></style><table dir="ltr" style="table-layout:fixed;font-size:13px;font-family:arial,sans,sans-serif;border-collapse:collapse;border:1px solid #ccc" border="1" cellpadding="0" cellspacing="0"><colgroup><col width="207"><col width="105"></colgroup><tbody><tr style="height:17px;"><td style="padding:0px 3px 0px 3px;vertical-align:bottom;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">Clutch Lever</td><td style="padding:0px 3px 0px 3px;vertical-align:bottom;font-weight:bold;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">E7TZ-7A554-A</td></tr></tbody></table>
You can get the entire pedal box assembly (which has the Clutch & Brake Pedal Bushing kit already installed).
<style type="text/css"><!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}--></style><table dir="ltr" style="table-layout:fixed;font-size:13px;font-family:arial,sans,sans-serif;border-collapse:collapse;border:1px solid #ccc" border="1" cellpadding="0" cellspacing="0"><colgroup><col width="207"><col width="105"></colgroup><tbody><tr style="height:17px;"><td style="padding:0px 3px 0px 3px;vertical-align:bottom;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">Pedal Box (Brake & Clutch)</td><td style="padding:0px 3px 0px 3px;vertical-align:bottom;font-weight:bold;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">F3TZ-2455-A</td></tr></tbody></table>
I wish I could find an exploded parts diagram, that would help to explain/show where all the little bushings go...
SonofaFord
09-30-2011 06:51 PM
sancochojoe
05-11-2005 10:55 AM
