Clutch pedal pushes brake pedal - Ford Truck Enthusiasts Forums
Old 08-22-2014, 06:07 PM
mcdimen mcdimen is offline
mcdimen is starting off with a positive reputation.
1987 F-150, new to me. Depressing clutch pedal slightly depresses brake pedal, enough to slightly engage brakes. I can pull brake pedal up with my toes, but it'll happen the next time I push down on the clutch. More pronounced when engine is running. I've tried spraying with lube but no luck so far. Please let me have your thoughts....thanks in advance.
Old 08-23-2014, 06:33 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
sounds like the bushing in the pedal assembly is worn out, causing the clutch to rub the brake.
Old 08-23-2014, 07:16 AM
How to fix
Thanks, Tom. Does the fix require pulling out the dash/steering column?
Old 08-23-2014, 07:42 AM
i ain't rite
can't really say for sure, i never fixed one. only heard of others doing it.
Old 08-23-2014, 08:10 AM
warren561 warren561 is offline
warren561 is starting off with a positive reputation.
Quote:
Agree. The bushings are shot.
Great write up with pictures of how to replace.
http://www.ford-trucks.com/forums/98...pic-heavy.html
Good info here too:
92 F150 4X4 won't start w/ clutch in and hard to shift - Ford F150 Forum
P/N for things you might want to replace while you're there:
<style type="text/css"><!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}--></style><table dir="ltr" style="table-layout:fixed;font-size:13px;font-family:arial,sans,sans-serif;border-collapse:collapse;border:1px solid #ccc" border="1" cellpadding="0" cellspacing="0"><colgroup><col width="207"><col width="105"></colgroup><tbody><tr style="height:17px;"><td style="padding:0px 3px 0px 3px;vertical-align:bottom;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">Clutch Rod Bushing</td><td style="padding:0px 3px 0px 3px;vertical-align:bottom;font-weight:bold;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">E69Z-7526-A</td></tr><tr style="height:17px;"><td style="padding:0px 3px 0px 3px;vertical-align:bottom;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">Clutch & Brake Pedal Bushing Kit</td><td style="padding:0px 3px 0px 3px;vertical-align:bottom;font-weight:bold;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">F3TZ-2C342-A</td></tr></tbody></table><style type="text/css"><!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}--></style><table dir="ltr" style="table-layout:fixed;font-size:13px;font-family:arial,sans,sans-serif;border-collapse:collapse;border:1px solid #ccc" border="1" cellpadding="0" cellspacing="0"><colgroup><col width="207"><col width="105"></colgroup><tbody><tr style="height:17px;"><td style="padding:0px 3px 0px 3px;vertical-align:bottom;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">Brake Rod Bushing</td><td style="padding:0px 3px 0px 3px;vertical-align:bottom;font-weight:bold;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">C9AZ-2474-A</td></tr><tr style="height:17px;"><td style="padding:0px 3px 0px 3px;vertical-align:bottom;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">Brake Rod Spacer (2 required)</td><td style="padding:0px 3px 0px 3px;vertical-align:bottom;font-weight:bold;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">C5DZ-2B129​-B</td></tr></tbody></table>
This part is metal, I can't imagine it would wear unless you left the bushings in bad shape for years:
<style type="text/css"><!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}--></style><table dir="ltr" style="table-layout:fixed;font-size:13px;font-family:arial,sans,sans-serif;border-collapse:collapse;border:1px solid #ccc" border="1" cellpadding="0" cellspacing="0"><colgroup><col width="207"><col width="105"></colgroup><tbody><tr style="height:17px;"><td style="padding:0px 3px 0px 3px;vertical-align:bottom;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">Clutch Lever</td><td style="padding:0px 3px 0px 3px;vertical-align:bottom;font-weight:bold;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">E7TZ-7A554-A</td></tr></tbody></table>
You can get the entire pedal box assembly (which has the Clutch & Brake Pedal Bushing kit already installed).
<style type="text/css"><!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}--></style><table dir="ltr" style="table-layout:fixed;font-size:13px;font-family:arial,sans,sans-serif;border-collapse:collapse;border:1px solid #ccc" border="1" cellpadding="0" cellspacing="0"><colgroup><col width="207"><col width="105"></colgroup><tbody><tr style="height:17px;"><td style="padding:0px 3px 0px 3px;vertical-align:bottom;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">Pedal Box (Brake & Clutch)</td><td style="padding:0px 3px 0px 3px;vertical-align:bottom;font-weight:bold;color:#000000;text-align:left;direction:ltr;border-right:;border-bottom:;">F3TZ-2455-A</td></tr></tbody></table>
I wish I could find an exploded parts diagram, that would help to explain/show where all the little bushings go...
Old 08-23-2014, 08:29 AM
Here's an exploded view of the brake/clutch assy I found (for 1980-1989 trucks). Maybe this will add to the conversation.
Exploded parts view for clutch/brake assy
Old 08-23-2014, 08:48 AM
More views of Brake/clutch pedal assy 1980-1989
Page B
Page C
Old 08-23-2014, 08:53 AM
quaddriver quaddriver is offline
quaddriver has a very good reputation on FTE.quaddriver has a very good reputation on FTE.quaddriver has a very good reputation on FTE.
you can remove all the parts while leaving the brackets in. it involves sliding the shaft to the side - but if it is somehow rusted, this may be hard to do.
Old 08-24-2014, 11:16 AM
Thanks, all. A little more WD-40 with the gas pedal almost in my mouth and I got it. Squeak is gone, pedals move independently, etc. Smooth as silk!!! Guess I dodged that bullet.....
? Replacing Clutch/Brake Pedal Bushings NinetyFiveF150 1987 - 1996 F150 & Larger F-Series Trucks 0 03-15-2017 09:51 AM
Brake Issues F750 Big Job NHSPRET 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 07-24-2016 08:52 AM
ZF5 Clutch pedal travel Bubba Jones 1994.5 - 1997 7.3L Power Stroke Diesel 6 05-05-2016 11:36 PM
Explain Ford's Cruise Control to me. Pele Excursion - King of SUVs 5 12-03-2015 08:40 PM
Brake Pedal Sticking to Floor jon1 Bronco II 2 06-25-2008 01:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
